RCA 5240 DVD - Audio Volume
Discussion in 'Blu-ray & DVD Players & Recorders' started by tozemko, Jan 23, 2002.
  1. tozemko
    tozemko
    Just purchased and installed RCD 5250P DVD. Connected to circa 1992 RCA 27" TV which has composite and S video input (not bad for its time).
    Put in 'The Patriot' as first DVD to view and set the TV volume at my 'normal' level for TV/VCR viewing thru cable. While the audio was fine - no crackling or hissing - it was much lower for the DVD which is annoying when you go back from the AV Input channel (91) to cable/VCR. I don't want to blow my TV speakers!
    An audio CD I played first on the DVD sounded louder and I thought this was great until I put in the DVD. A second DVD also sounded lower ( that is I had to crank the TV volume up.......)
    I played with all the menus, RCA support isn't helpful. Does anyone know if this is what I should expect by going thru an older TVs av input?
    Thanks.
  2. tozemko
    tozemko
    Should add that I have heard use of a better (thicker gauge) audio cable might help?????The ones that come with unit are pretty flimsy.
