rca 50" ethernet connectivity
Discussion in 'General TV Discussions Forum' started by ken k'niff, Sep 17, 2005.
  1. ken k'niff
    ken k'niff
    My problem is that i cant get my tv to connect through the ethernet port. Even though the instructions say that it should be able to autodetect settings through a dhcp enabled router, of which i'm using (linksys wireless g). I was wondering if anyone had any info on how to get this to work so i can view pictures etc. off of my computer on the tv without burning them to a dvd or cd. any help would be greatly appreciated.
    K'niff
  2. ken k'niff
    ken k'niff
    anyone? at all?
  3. Chumpy
    Chumpy
    Sorry but if the make is RCA then this'd probably make it as US TV. As a majority of the visitors here are from the UK where we can't get this TV, I don't think you will get a response. You could try the US sister site http://www.avsforum.com
    You may have more luck there.
  4. ken k'niff
    ken k'niff
