RC6 Code: which remote?
Discussion in 'Home Cinema Control & Remote Controls' started by sr78, Feb 8, 2003.
  1. sr78
    sr78
    Sep 26, 2002
    282
    I'm considering buying the Philips 963SA. As most of you know, this player can be made code-free using an RC6 remote hack. Apart from the Pronto, what remotes can generate this RC6 code? The remote should be able to use codes for Philips, Arcam, JVC, Marantz and Pioneer products.
    I heard some of the OneforAll remotes can do it, but not which ones. Personally, I'd like to have the TopLine 8 or the Kameleon. How about Philips' own universal remotes? Can they also control other manufacturer's equipment?
    Finally, I already have a semi-universal remote, the remote that came with my Marantz SR4200. Can this remote generate an RC6 signal?
  2. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    the one for all 3(urc-7030)from argos etc,£19.99 .
  3. sr78
    sr78
    Sep 26, 2002
    282
    Thanks, but I need one that can operate at least 6 devices (TV, DVD, 2 amps, VCR, CD).
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    One For All 6 ( URC7560 ) definitely works the 963 MR hack.
  5. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    do you know if that does all the region hacks
    i'm getting a sony ns405 and the hack says you need to use a pronto or a palm to send the codes
  6. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    +32
    It needs HEX codes so a pronto type is required as far as I know.
    I'm not aware of a hack without one, sorry.
  7. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    so this isn't possible with the all for one remote controls?
    :mad:
  8. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    +32
    I'm really sure it isn't.
  9. fraggle
    fraggle
    Dec 11, 2002
    1,496
    Milton Keynes
    +54
    Moderator comment - Moved to Remote controls forum.
