rc5000 light sensor
Discussion in 'Home Cinema Control & Remote Controls' started by chaz, Jan 23, 2004.
  1. chaz
    chaz
    Apr 7, 2003
    3,242
    87
    sussex
    +158
    Hope someone can help me i own a Marantz R C 5000 its great expect that on the box and also in the user guide they show a light sensor on the right top corner so you can ajust the light when it comes on mine has not got this light sensor but it has got the page on the remote to ajust it have i got a odd one:eek:
  2. Zone
    Zone
    Jun 24, 2001
    6,527
    Barnsley
    +2,115
    Lifted from RemoteCentral.
    All recent remote models do not feature the light sensor due to European environmental restrictions. The light sensor contained trace amounts of a banned substance, and as all models are manufactured in Belgium it was removed altogether.
    Although units with a light sensor place it under a small clear circle near the top right-hand corner of the remote, all remotes with that spot do not actually have the sensor.
    To check if your unit truly has the sensor, go to the remote's setup menu by pressing and holding the Pronto icon for three seconds. Scroll to panel two. If the "Light Sensor" bar constantly reads 50% and will not change by changing the lighting environment around the remote, it does not have the light sensor. If the bar jumps around and appears to reflect the current lighting situation, it has one.
