RB250/RB300 with Emotion tt..need advice
Discussion in 'Hi-Fi Stereo Systems & Separates' started by etach, Sep 21, 2007.
  1. etach
    etach
    hi all,
    my 1st post here..need some advice..my tt right now is MMF2.1 with Bias 2 MM cart..
    i'm thinking of getting a 2nd tt..i'm more to Pink Floyd, Radiohead, Coldplay, Cranberries, Queen..I'm thinking of getting the Emotion and then pair up with a RB250/RB300..my budgwt is around 550 pound
    1. has anyone tried this?
    2. will the RB tonearm fit perfectly?
    3. or should i just stick with the satisfy tonearm?
    thanks all for the input.. :)
  2. cwilson
    cwilson
    Feb 5, 2005
    403
    scunthorpe
    why? if you want the emotion, stick with the arm it comes with, If you want a Rega Arm, then either the new P3-24 with RB 301, or look for an ex dem P5, with RB 600, you should find one in budget with a psu unit. I think the Clearaudio's use Linn geometry rather than Rega.
  3. etach
    etach
    emotion/Rega tonearm (420+125 pound) combo vs emotion/satisfy (690 pound) combo would have a big price difference where I came from..
