Raw "naming" question.
Discussion in 'Photography Forums' started by Steve N, Jan 2, 2007.
  1. Steve N
    Steve N
    Feb 3, 2005
    10,936
    Peterborough
    +2,383
    I'm hopeful that this is an easy one for someone.
    Any pictures I take in jpeg (any quality) get named and transfered to my pc with no problem.
    However, when I try and put Raw (Nef) pictures in using my Nikon NX I get a message asking if I would like to replace files as there are files of the same name already stored.
    I then have to rename all my new shots to allow them to be transfered without overwriting existing shots.
  2. Radiohead
    Radiohead
    Dec 24, 2001
    4,418
    Amazingstoke
    +442
    Do you have file naming/numbering set to start from 001 each time the card is loaded?
  3. Steve N
    Steve N
    Feb 3, 2005
    10,936
    Peterborough
    +2,383
    Thanks, I'll check that out.
