Raw & JPEG
Discussion in 'Photography Forums' started by Thomas Gee, Aug 25, 2005.
  1. Thomas Gee
    Thomas Gee
    I have a Nikon D50 with a 18-55mm & a 70-300mm zoom lens with 3 512MB SD memory cards. Would it better to take photographs under RAW format or using JPEG fine (large)
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Well you have much more control with RAW it's basically a digital negative. You'll need a bigger card/some more cards as they're large files.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    And a bit more time for processing......... :eek:
  4. longleyc
    longleyc
    Should be Noise free too.
  5. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    You still get noise in RAW, processing is generally less deleterious though.
  6. Radiohead
    Radiohead
    Dec 24, 2001
    4,380
    Amazingstoke
    +431
    Unless you're sure you can nail the WB and exposure with every shot, shoot RAW.
  7. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    With software like RSE you can work on batches of images, it's not really that time consuming and I think it is quite fun. Also, as you have more information in a raw file so you can nail tone curves down to exactly what you want (this is about contrast and levels and nothing to do with correcting exposure), something you don't have as much latitude to do with JPEG. Plus, every time you save a JPEG it can lose information due to compression, you've always got the original with raw.
  8. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    where did that come from????
    the noise is created by the sensor, rather than the file format. just like the grain on high ISO films
    i shoot exclusively in raw, i prefer it
  9. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    You can't batch process if you want to do them properly. :lesson:
    Each picture will require its own individual processing.
    You wanna try sifting through 1000+ RAW files on a Sunday evening. You'll need Monday off work..... :eek:
  10. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    Not true. If the exposure and white balance are fine then you can do a straight conversion to JPEG or TIF of a whole load of images without any other processing. Images taken under similar conditions, e.g. multiple shots of the same subject can generally be batch processed as well. This is why the batch features exist within DPP, RSE and other raw conversion utilities, because you don't need to work on each image individually.
  11. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Sorry, totally disagree...
    The idea of RAW is to adjust exposure white balance colour saturation etc for every picture.
    You will be either extremly lucky, or a brilliant photog to get a whole days shooting correct in every single shot.
    What about Unsharp masking too....every picture is differant, requiring a varying amounts.
    Batch processing is only really useful to batch resize in my experiance.
    If you want quality, it takes time....
    All RAW images are 'flat' as a negative
  12. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    kind of half agree with john here, i do every single image individual, however if i had a rook load of studio portraits all taken exactly the same then yes batch processing would more than likely be fine.
    raw just gives me the opertunity to meddle with every image how i want it
    for me batch precessng is of use for resizing, adding borders etc
  13. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I sometimes batch a load of similar images, usually just for colour adjustments but then open each one to crop and sharpen. Used to use Russell Brown's Image Processor for batch processing RAW files but that functionality is now built into CS2 - which is a godsend (its still worth downloading if you use CS).
    Got 600+ RAW shots to get through tomorrow - ranging from bright sunshine, church interior, stormy cloud cover, dusk, candle light and bulb lit marquee. Not much batch processing there unfortunately :(
  14. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    And yet there have been people on this forum that have made exactly this claim as their reason for shooting in JPEG.
    Batch processing works perfectly for me, lets face it, that's kind of what you are doing in camera when shooting JPEG, the camera is applying a predefined setting to convert the raw data to JPEG - it's applying the same saturation, contrast, sharpening and white balance to all images, just in camera. Are you saying that you can't take good pictures in JPEG? And if you need to manipulate the JPEGs afterwards then that takes the same amount of time to manipulate the raw file, so no extra time difference between raw and JPEG which ever way you look at it.
  15. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I batch process groups of shots without a problem... you can do them one at a time if you prefer but experience tells me it's very rarely worth it as you'll end up applying very similar settings over and over.
    Individual shots do need individual tweaks, again in my experience.
  16. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    And thats the reason I mainly shoot jpeg.
    I have used RAW and will use RAW again. What I have never done is shoot RAW without a camera produced JPG as well. I have my in camera parameters set to produce jpgs as I prefer them.
    When I spend time going through the RAW's and processing them I would have expected to see significant improvement over the camera jpg. From my experience 90% plus of the final outputs after processing are no better than the jpg from the camera. The other 10% are mostly exposure corrections that could be applied to the jpg.
    Don't get me wrong - I am not anti RAW. I just don't have the time or inclination to spend tweaking for little gain. In difficult situations RAW can be a saviour and I will use it.
    As to colour balance - I can't do it. I am partially red/green colour blind (you know those dot picture tests? - I can see both numbers on top of each other). I can change it to what looks right to me - and no one says it looks wrong.... equally if I leave it alone no one comments either. So unless its extreme I leave well enogh alone :D
  17. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I take superb pictures in jpeg, so damm good, I hardly ever need to use RAW.. :cool: :D :rotfl:
    I also process all my jpegs, and its much quicker than starting with a RAW file, as the Workflow is much shorter. And yes...I have spent a day shooting in RAW to compare processing time.
  18. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I just prefer what i get from RAW to that the 20D generates on its own...so bear the cost of the extra step, in the same way i bear the cost of L glass i guess. I'm sure as digital progresses the day will come when i can't tell the Jpeg from the camera from that generated with RAW processing and that will be when i stop using it.
  19. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    my computer dislikes Jpegs, infact it wont display them for a while after the folders been opened up, instead i use the file browser in the raw program as it is much quicker and easier.
    dont really like Jpegs anyway, i work in .tif most of the time, and only save to Jpeg for web use/ giving to the customer
  20. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Little Tester......Guess which are shot in jpeg, which were shot in RAW.
    No cheating looking at exif data.......cos I've removed it... :D
    You could guess the L glass too.... :smashin:
      Size:
      91.9 KB
      61
      Size:
      88.3 KB
      54
      Size:
      96.8 KB
      55
      Size:
      95.3 KB
      56
      Size:
      98.4 KB
      53
  21. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Pics 1 & 3 are RAW and L glass.
    Pic 4 is JPEG and L glass.
    Pics 2 & 5 are JPEG and not L glass.
  22. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I don't want to give away yet.....anyone else?? :D
  23. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    I didn't know you had L glass, John, you've never mentioned it before :D
  24. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    :D Gonna have a crack at the pics then.....Its gonna be a good test between standard and L glass, RAW and jpeg.
    I think some might be suprised.. ;)
  25. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Don't be shy now.......guess the answers... :D
  26. Thomas Gee
    Thomas Gee
    Johndm
    1 RAW, 2 & 3 RAW & L Lens, 4 & 5 JPEG
    By the way can I use the Phantom as my screensaver?
  27. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Wrong....... :D
    I want to see a few more guesses before I reveal the truth..
    I think all this might just prove that you can't tell the differance between RAW and Jpeg....a quality picture speaks for itself... :cool:
    Sure you can use the Phantom....PM me your email, and I'll send you a 1024 wide version.... :smashin:
  28. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    here's a different answer. I shoot raw so that when i fudge the exposure on an otherwise good shot I can correct it and get a good shot, but then I'm human.. To me it seemed good to +/- 1.0EV no problem and maybe a bit more if you're lucky.
    Also I find D Lighting in Nikon Capture 4.2 awesome for fixing my flash messes, or imperfections when I dont get the bounce quite right and I had to do it in a hurry.
    But I quite like the JPG as well because I sometimes don't have the time for RAW.
    So RAW when its a good or great shot that you need to perfect the exposure and JPG for everyday shots when life's too short - or is that heresy in the forum.
    Rajiv
  29. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    20 views per picture, but only 2 guesses.... :thumbsdow
    Are we afraid that jpeg/kit lens will blow RAW away... :rotfl: :rotfl: :rotfl:
  30. Radiohead
    Radiohead
    Dec 24, 2001
    4,380
    Amazingstoke
    +431
    I'd say the only RAW was no.3 and that was with L glass as well.
    Having studied them in depth for all of 3 seconds that is my considered opinion.
