raw files
Discussion in 'Photography Forums' started by paulc1, May 23, 2005.
  1. paulc1
    paulc1
    Oct 19, 2004
    392
    +28
    I have shot and processed my first raw file from my D70, and cannot believe what I have been missing by using jpeg format, I am using Nikon capture, which is great but really really slow, and I am using pixmanted rawshooter, which is better, but doesnt process the files as good.
    does anyone have any recommendations?
    I dont think that I will ever shoot jpeg again....ever!
  2. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +22
    i use rawshooter, not had any problems
    try adobe camera raw if you use photoshop or elements
    i find that, although sometimes i just want to run of some quite snaps so i revert to JPEG format and then forget, take a few blinding shots in JPEG that i then want to tweak in raw and cant
    i agree im a raw convert, try to keep away from JPEG now :D
  3. paulc1
    paulc1
    Oct 19, 2004
    392
    +28
    I use photo shop 7 and the raw plug in wont work with it, i think it may be upgrade my processor and memory time.
    I simply cannot believe the difference between raw and jpeg...its like a revelation, and I am more than happy to struggle with long processing times, just to see the results.
  4. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +22
    yeh i think the raw only works with CS
    yep its well worth it, the tweakability is superb, i managed to get some wedding shots from a strange angle that no one else could get, and by bringing the exposure down they look superb :)
  5. dejongj
    dejongj
    Sep 11, 2003
    28,191
    Beautiful South
    +4,565
    For a simplified workflow I can highly recommend Adobe Photoshop Elements 3.0...I only shoot in RAW and it makes it really easy to use......
    Though I think that for my holiday I will move to raw+jpg so that I can offload my compactflash cards to my Ipod Photo and view the images...
