Rattling sound monolith df
roosterx
I believe i've read somewhere here about this topic but i couldn't find it on search so here i go..
I just reinstalled my HTPC and to check that HD codecs bitstreamed like they should i put on my 'Cloverfield' blu-ray, then i for the first time noticed it sounds like something is loose inside my Monolith, it is a rattling sound coming from inside my sub when the bass goes quite deep(intro logo on Cloverfield), anyone have comments? I am thinking it could be as simple as a wire that is loose inside it, if i remember right i can without invalidate my warranty open up my Monolith?
Badger0-0
Yes, you can open it up as long as you're careful and don't butcher things :)
Could well be a loose wire or whatever, as you say.
roosterx
Thank you for clearing that out, i will maybe look into it tomorrow. :)
