ratDVD
Discussion in 'Desktop & Laptop Computers Forum' started by Moosh, Jun 7, 2005.
  1. Moosh
    Moosh
    Sep 12, 2004
    2,002
    2
    Bristol
    +469
    This may be of interest to the HCPC people.
    http://www.ratdvd.dk/index.htm
    It's a program called ratDVD that allows you to save the entire contents of a DVD in a highly compressed .ratDVD file. It requires Windows XP, DirectX 9 and Windows Media Player 10.
    If this program lives up to what the author says then it'd be a great way of saving all of your DVD's on a HCPC's hard drive. The only downside I think is:
    Moosh
  2. betamac
    betamac
    I dont think serious AV people would be happy losing Dolby 5.1 or DTS myself
    Movies dont take that much room anyway if you just rip the movie + preferred soundtrack to store on hard drive
  3. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,313
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    i wouldnt lose :dts: or :dd: ever simple. think i will stick with my 300gb HDD and using DVDShrink to rip dvd's uncompressed and unaltered
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,049
    +2,982
    You can keep the DD or DTS if you want it.
    It is a good program but, it isn't designed for HCPC use. It is for uploading/downloading of the net.
  5. rhumber
    rhumber
    Nov 23, 2005
    73
    9
    Nr Bedford, UK
    I've used this program for the last couple of weeks.
    Is it me or is the video not as good as normal torrents?
    I downloaded a couple of movies and they seem to be worse quality than normal.
    I guess it compresses video also in the ratDVD format, so when you convert to a dvd it's worse than normal is this right?
    I just seem to get this video blockiness that I haven't really seen before.
    Just that the RatDVD format is so good as the torrents are 1/4 the normal size which makes downloading much easier!
    Thanks for any comments...
  6. bad robot
    bad robot
    Mar 14, 2004
    3,130
    +349
    Personally my view is that with the advent of HDTV the last thing most would want is even more compressed video, particulary at the loss of audio and video quality. These things surely are more suitable for portable media solutions, well just my views...
    Considering the price of harddisk storage continues to drop and will have to reach a new capacity or who knows maybe approx 20p per gig or less within the year. All because HDDVD / BLURAY PC drives and blank discs should become widely available, but ultimately requiring larger files/storage for HD material will even out with price reductions just as DVDs changed things in the past...
    I remember in the days of 56k paying £220 for a 40GB drive thinking id never fill it, mmmm
