Raster Size
Discussion in 'Projectors, Screens & Video Processors' started by Alaric, Mar 10, 2003.
Thread Status:
Not open for further replies.
  1. Alaric
    Alaric
    Mar 12, 2001
    1,759
    Peterborough, Cambs, UK
    +149
    Hi there,
    Just setting up a BD800, and going through the set-up procedure in the manual, Manualy focused the lenses, then got onto raster centering.
    However it apears as though the rasters are bigger than the sides will allow, ie if i shift the raster so its just inside the left side, the right hand side is off the tube ????
    It also looks like the height has been compressed.
    I guess its been an atempt to get a better 16:9 image or something, but it doesn't seem right.
    Anyone know anything before i spend hours delving though the service manual to find i need some specialised equipment to set the voltages or something equaly silly.
    cya,
    Lee
Thread Status:
