Rant About Consoles Connections
Discussion in 'Nintendo Forums' started by sleepyone, Nov 11, 2004.
  1. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
    <Rant On>
    So there I was wiring up my new GC, having to pull out the x-box as i do not have enough connections when I had a great idea.
    Lets buy a Av connection box and s-vdieo connections for my PS2, X-Box and GC. Anyone spot the disaster thats about to happen?
    Went on the web, got a great deal from Lik_sang for an av-switcher and s-videos leads. 2 weeks later and everything has arrived and I plug it all in.
    X-Box, wow, instant improvment. PS2, same again great picture.
    GC, hhmm, blank screen, maybe I have to change a setting, quick rummage through the manual and the settings. Maybe there's something on the web?
    5 mins Browsing later....What the :censored: do you mean s-video wasn't implemented in PAL gamecubes, I just spent 10 :censored: quid on a gc s-video cable. :censored: :censored: :censored:
    They put a bloody usless digital out on but not s-video which is on more TV's than component.
    :censored:
    <rant off>
    Okay, feel slightly better now. Surely if sony and Microsoft can put the different connections on their boxes then why cant Ninty?
    So is there any way I can mod the GC to work with the cable, otherwise i've still got to pull something out to plug the GC in?
  2. t-force
    t-force
    May 2, 2001
    1,861
    Southampton, UK
    +151
    Nope, they removed the S-Vid so that they could put RGB onto the UK cube - hence the reason it's rather a difficult task to get RGB from an NTSC cube.
    You reallly have four options open to you, in increasing order of quality:
    1) Use the composite feed - not recommended,
    2) Sell your PAL cube and buy an NTSC one, because they do have S-Vid.
    3) Use an RGB cable - a lot better.
    4) Get a component cable, a copy of Freeloader and revel in the prog scan goodness that NTSC games offer. Of course, if you don't have a TV with component inputs or prog scan this isn't much of an option.
  3. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
    thanks for the info t-force.
    I do have component socket on my TV but that is used for the DVD player.
    I know RGB was probably the best option but the whole point was getting all three consoles to run off the one socket.
    Ah-well, I'll have a look around the back of my telly see if can move some scart cables around, I got 2 RGB scarts so will try to organize something.
    Thanks Anyway.
