Link bounties with story missions to boost xp and leave gear in the vault from your main character
Yes it would. I didn't go this route though, I prefer to have the variety.Forgive my ignorance, but by an alt do people mean a 2nd character of the same class as opposed to a different second character?
I have been thinking about starting a 2nd character and was toying with the idea of a titan as the bubble seems especially useful. The prospect of grinding it up to level 28+ was putting me off though.
Then I had a thought last night, can I start a 2nd Hunter character, then once he/she reaches level 20 I can just vault my upgraded armour from Hunter No.1 to go straight to level 29? Thus giving me 2 attempts per week at getting raid gear, would that work?
That'll work fine many here already do that.Forgive my ignorance, but by an alt do people mean a 2nd character of the same class as opposed to a different second character?
Yes, I made a 2nd Titan and did/do this.Forgive my ignorance, but by an alt do people mean a 2nd character of the same class as opposed to a different second character?
I've got a level 7 Warlock that I'm planning on levelling up tonight. I've got as far as finishing all of the Earth story missions. Going to start on the Moon at about 8pm. If you want, we can do some co-op levelling.If anybody sees me doing a mission story or bounty feel free to jump in and help out! Much appreciated!
Right, I think I am going to start a 2nd Hunter tonight to quickly get up to level 20 and double my chances of raid gear etc next week. Can then stockpile/vault hopefully some legendary/exotic armour for a titan which I'll start the next week or whenever the alt is leveled up, as then I will only use for 2nd raid/nightfall runs.
@Agrav8er , @DroidSkin , would also be up for some co-op low level leveling up action.
Also, thinking could one person sign in as their main, team up with the 2 low level alts and then effectively solo the daily 28 level mission with the other 2 hiding/sniping at the back. Can you do that? Would it give a better XP return than say, 3 level 6's grinding through a level 8+ story mission?
Might be a bit dull but am up for blasting through levels as quick as possible.
The main character would be fudged to the damage levels of the low level toons, IIRC mate. Wouldn't work.Right, I think I am going to start a 2nd Hunter tonight to quickly get up to level 20 and double my chances of raid gear etc next week. Can then stockpile/vault hopefully some legendary/exotic armour for a titan which I'll start the next week or whenever the alt is leveled up, as then I will only use for 2nd raid/nightfall runs.
Try not to do story missions.If anybody sees me doing a mission story or bounty feel free to jump in and help out! Much appreciated!
You big tease!Try not to do story missions.
I'll explain more later
