Random question about satellite dish
Discussion in 'Satellite TV, Sky TV & FreeSat' started by scotty69, Mar 12, 2013.
  1. scotty69
    scotty69
    Dec 21, 2012
    10
    Does anyone know what size the coach bolts are that are used to secure the sat dish together?
    Thanks in advance Adam
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Which model of sat dish?
    There must be dozens... :)
  3. scotty69
    scotty69
    Dec 21, 2012
    10
    Just a normal sky mini dish
  4. logiciel
    logiciel
    Feb 2, 2008
    53,126
    UK
    +5,768
    :confused:
  5. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    There have been four different versions over the years, two different sizes and several different manufacturers - so more info needed or a photo of dish plus dimension across dish face. There is no normal Sky dish.
  6. cyprusstudio
    cyprusstudio
    They are not held together with coach bolts, but fixed to the wall with 10mm coach bolts (10mm holes).
    They are held together with self tapping screws, and short bolts with 10mm nuts.
  7. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,651
    Cheshire
    +1,079
    that's actually a zone 2 & quite a different design from the popular zone one's & the arm type plus the lnb fitting is different.
    I did find another but just look what happens to the bricks & mortar line @ 5:39:eek:
    making&install dish - YouTube
    The mortar joint had clearly already failed to the right but you should really be looking at the building & wall you are working on not just fitting a dish, especially doing a video of it:facepalm:. (should use the bricks in most cases btw)
  8. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    That video horrified me.
    Installer took the easy option of mounting into the mortar joints - bad idea. You can see the cracks appearing already; what would happen once the wind imposed some real stress on the fixings ?
  9. scotty69
    scotty69
    Dec 21, 2012
    10
    They are fixed to the wall with coach bolt screws, I'm after the short coach bolts which hold the arm in place. You say they are also 10mm
  10. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,651
    Cheshire
    +1,079
    It's quite funny really ... "you were only putting a sky dish up ... & you couldn't get that right ":facepalm: :rotfl:
    It wouldn't be funny if it fell on someone or resulted in much more serious building damage, but you do see plenty of cracks/ poor & failed mortar joints etc.. & the other end of the scale- some really good construction ... that looks like either a poor mortar mix &/or maybe it was built in really hot weather & allowed to go off too fast..
    not sure about using a 24v to screw them in either - you can't feel what's happening.... more a "how to chuck up a sky dish".
  11. cyprusstudio
    cyprusstudio
    That's a bolt, not a coach bolt, their's the confusion. I think it's a m8?, but the bolt has a 10mm nut. Try your local ironmongers/fixings shop, they should be able to help you, take the dish with you.
