RAM - what is forced verify mode?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bobones, Oct 14, 2003.
  1. bobones
    bobones
    Jan 15, 2002
    453
    +7
    The instructions of some caddied RAM media I have says the media will revert to forced verify mode if it's removed from the caddy. Can anyone tell me what this means and what the consequences are?
    I have an E50 and was thinking of buying this Panasonic dvd writer for my PC.
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    This relates to data recording. It simply means once removed a PC Writer will not let you turn verifying off, so it will write and read back to check it was recorded okay whether you want it to or not.
    I do not think this makes any difference with set-top recorders as it isn't so important to have 100% data integrity on Video.
    Regards
    Philip
