RAM timings
Discussion in 'Computer Components' started by Berties, Nov 29, 2010.
  1. Berties
    Berties
    Apr 21, 2009
    8,393
    +604
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,757
    WEST MIDLANDS
    +1,482
    No, according to the specs they should be 9-9-9-20 and 1333Mhz in CPU-Z its showing as 8-8-8-16 and only 1070Mhz.
    Unfortunately i'm not familiar with AMD setting so i'll leave it to someone else to tell you what settings you need to change in the bios ?
  3. Berties
    Berties
    Apr 21, 2009
    8,393
    +604
    cheers, adjusted easy enough (increased to 666 and altered other settings automatically)
  4. Berties
    Berties
    Apr 21, 2009
    8,393
    +604
  5. Berties
    Berties
    Apr 21, 2009
    8,393
    +604
    ok adjusted, looks right? Is RAM speed correct now?
  6. Ted
    Ted
    Apr 4, 2001
    250
    28
    Surrey
    +38
    Both look right, if you encounter any instability try setting command rate to 2T, assuming you already have ram voltage set to manufacturers specs.
    Just for info, the timings table in the SPD tab is just the inbuilt timings table on the ram itself, set by the manufacturer to show what latencies it can officially run and at what speed, not what is actually running.
  7. Berties
    Berties
    Apr 21, 2009
    8,393
    +604
    ta, running fine both 1T RAM.
