cabbie19
Hi, due to an unexpected windfall i'm thinking of upgrading my motherboard to an ASRock Z68 extreme7 Gen3, i will keep my i5 2500k and existing gpu.
I would appreciate advice on a GOOD set of 8gb or 16gb memory, what speed and timings (CAS) would maximise my o/c potential. Also what voltage would be best?
I currently use a Gellid Tranquillo cpu cooler, is there a better one, i cant go any taller than the Gellid's 153.3mm
Thanks all, jamie.
Thanks all, jamie.
