RAM disc problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Northerner, Sep 21, 2003.
  1. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    The land where The Macallan is distilled
    Checking through my discs, I've found a RAM disc that apparently, is blank but it is "write protecetd" and I can't undo this. Direct Nav says the disc is not recordable. I don't know if I've ever used this particular disc before.
    Being a canny Scot I don't want to ditch it if it can be corrected;)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,218
    Argyll
    +2,267
    Is it in a Caddy? If so is the little write-protect button set to 'write'? On Panny disks (and most others) this means the little button should be at the bottom when the disk is held upright.
  3. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    No:(
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,218
    Argyll
    +2,267
    Do you have a PC DVD-RAM drive with write abilties? If so try formatting the disk and see if that makes a difference? You could try formatting on the E50 but, if it insists the disk is write-protected, it might not let you.
  5. Northerner
    Northerner
    Aug 12, 2003
    112
    19
    :clap:
    You've done it again - thanks
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,218
    Argyll
    +2,267
    No problem mate. The software write-protection option you can set on the E50 (and what somebody obviously set for you by mistake) can't survive a quick (or full) format so if you ever run into problems like that on new disks just format it and all will be well.
  7. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    Also be aware that DVD-RAM will switch to read-only mode if it detects surface damage (scratches or dust) or has to re-allocate alot of sectors due to writing or reading problems. This is more common for non cartridged media. Formatting will re-initialise the disc, but it might switch again once it starts being used.
    See : http://panasonic.jp/dvdram/english/qa/rq102xx05.htm
    Regards
    Philip
