Quantcast
RAM and network speed.....
themediaman
Just got a new router that is Gig ready, I was not expecting Gig speeds, but only really got doubl my transfer speeds, which I know can be common when considering equipment [hard drives, RAM, CPU etc....]
Would increasing my PC RAM help with the transfer speed from it to my NAS/Other external hard drives.........
Thank you...........
Kristian
Very doubtful. It may but only if the OS and apps you are running don't have enough RAM for themselves and are constantly having to use the page file. You are much more likely to be limited by the [lack of] speed of the hard disks in the source and destination devices and processing power of CPU, the latter especially in lower end NAS.
themediaman
thanks for your reply.................
I have the readynas duo, so low end NAS..........not expecting a lot.....
charles_b
It's on a par with what I get with my Duo...I think Windows 7 is to blame to be fair. I've not yet tried Linux Mint transfer speeds on Gigabit (I only have a 100Mbit Mint Laptop), but transfer speeds are better on linux it seems, have you checked your MTU settings across the board?
themediaman
I have not, but have been reading up on it today.............
The jumbo frames setting on the Duo is enabled on my unit, but I am unsure whether my PC NIC supports it, will check tonight after work, seen a Command line used to check if the MTU setting functions................any experiences on this..........[ping -f -l MTU IPHost]
Will other devices on my LAN affect the speed between PC and NAS, like my PS3, Surround AMP..........?
Kristian
I don't believe jumbo frames do much on the ReadyNAS DUO to improve performance. All the devices in the chain e.g. PC, Switch and NAS need to be able to support JF. It's generally advised that unless all devices in the network support it then don't bother.
The DUO tends to max out at about 25MBytes/s and it's due to the CPU I believe. Which is about twice the 12.5MB/s limit of 100Mb Ethernet.
themediaman
Thats useful information, thank you.........
themediaman
fiddled about with my NIC configuration changing the jumbo packet size to 9514 bytes and went from 8.736 Bytes/sec to 16.798Bytes/sec write speed, so good news...........
Similar threads
