Hi, quick question for the RAKO experts on the forum. I had emailed RAKO directly, but no response as yet:-
I'm in the process of putting together a Rako system in a large
"family room" extension. One of the circuits in this room will be
intended for switched, non-dimmable flourescent uplighters for which I
wll use a RDS800C. This will be used in a scene with some dimmed
channels running from RDL250s & 500s, and I was wondering how will the
switched output will function when the master raise lower buttons are
used?
For example, say I have all channels at 100% in a scene, and then
use the master lower button to drop the level of all channels, the
dimmable channels obviously start to dim, but what about the switched
device? Does it wait until the level reaches 0% before switching off,
or is there another threshold like 50% ?
used?
