Raise Centre Speaker
Discussion in 'Home Cinema Speakers' started by a l e x, Jan 9, 2012.
  1. a l e x
    a l e x
    Jan 3, 2009
    7,743
    East Yorkshire
    +2,540
    Currently my centre speaker is in its gap in the unit flat on the shelf. Its a lowish shelf and the centre is probably in line with by stomach... looking for something simple to raise the front of the centre so its angled up towards my head... any recommendations?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,230
    +5,404
    You could either use some blutac or cut some squash balls in half and use them.
    Speakers do not like to be put in cabinets so if you could find a way of positioning it elsewhere I am sure you would hear improvements in sound quality.
