Question Raid 5 controller card
MeGuinness
Hi guys , my Synology 4bays Nas cannot cope with the amount of data I'm throwing at it 😄 so decided to build a Nas to accommodate many more hdd's.
I would need suggestions about which raid 5 controller card to purchase without the need to remortgage my house lol..., any recommendation please, I'm looking for 6 to 8 ports .
thanks
brunation
Not sure about the RAID5 but maybe you're after something like an AOC-SAS2LP-MV8 ?
Any parity protection would be done in software via the filesystem.
andybond
Are you sure it’s the raid controller that is slow and not the spindle speed of disks?
edd666999
If money is a issue, look at using freenas and a few Dell PERC H310 flashed to IT mode.
mjn
As above, use FreeNAS, and then you don’t need to worry about buying an expensive RAID card. If you do want to go hardware RAID, you can usually pickup a cheap HP SA with battery backed cache on ebay.
Similar threads
