Raheel's HTPC + Gaming Machine (load's of pictures) and future updates...
I call fake on that 'after' pic - far too good! Are you sure you just havent unplugged everything and taken a pic? :eek:
Very nice job! :thumbsup:
Razor
Much better mate. Now get a custom cpu cooler like a mini ninja if you intend on overclocking. :smashin:
theraq
I don't see any pics :confused:
...Now i do maybe i just needed to be logged in. Very nice any pics of it running?
Thanks! will take soon and post them in running state. btw you can check couple in my img album...
:thumbsup:
theraq
LOL! no its true! my laptop is donkey and taking time to resize pics... I will resize them tomorrow and show how I done the cable management!
:smashin:
PS: all cables are plugged! not a single cable unplugged from their connectors. :cool:
theraq
Thinking about OC but I will test my processor and case temp first also will install the fan's you mentioned... than OC it!
About ninja Intel board is not compatible for any cooler :mad: (I mean my config due to ram size and cpu position)
:thumbsup:
Razor
The ram is very close to the mini ninja in my 775 pc but it can fit. I would get rid of the stock cpu cooler straight away. They are noisy and poor at cooling. They also just blow the hot air around the htpc case instead of directing it towards the back fans where it can exit the case. If you want performance and silence swapping out the stock cooler is a must. It will help your temps no end.
theraq
Thanks! do you have a pic of it? :confused:
Razor
eiren
The alternative to the Mini Ninja is a Noctua NH-U9B (I've got one :devil:).
It's 1cm taller than the Mini Ninja but it's not as deep so it's nowhere near as close to the RAM and other motherboard stuff :thumbsup:
I'm using one at the moment to run a Quad Q9550 at 4.08GHz on air, and it's keeping load temperatures below 70 degrees C... even when using the Intel Burn Test. Absolutely brilliant :thumbsup::clap:
You can send away to Noctua to get the 1366 adaptor for it too... all FREE.
http://www.noctua.at/main.php?show=productview&products_id=17&lng=en
http://www.noctua.at/main.php?show=productview&products_id=23&lng=en
http://www.quietpc.com/gb-en-gbp/products/intelcooling/nh-u9b
theraq
Just ordered...
1 Noctua NF-B9-1600 Vortex-Control 92mm Quiet Case Fan £11.49
2 80mm Noctua NF-R8 Quiet Case Fan £24.13
theraq
Thanks :smashin: but if you read this review... which seems will not fit in my config :mad:
theraq
Razor: do you have that cooler in spare? so I can test it :D
Razor
Sorry mate I dont. :rotfl:
Thats a shame it doesnt fit. If I was in your shoes I would measure the space between the memory and the middle of the cpu to work out how much room you have to play with. You cant leave your setup with a stock cpu cooler, that would be criminal. Do you know what coolers will fit your mobo. If you have a list post it up and we can help you pick a decent cooler.
BTW well done for buying new fans. :smashin:
eiren
That's not the same cooler. The one in the review is the Noctua NH-U12P.
If the Noctua won't fit because of RAM layout, then the Mini Ninja definitely won't as that starts lower down and has a wider foot print.
In fact you'll be hard pushed to find a good cooler if neither of those fit. You're better off swapping that motherboard and getting the Asus or Gigabyte motherboards.
theraq
Off topic:
Just bought Sony KDL-40Z5500 for bedroom.. will take some pics and create a new post for my main and bedroom system.
Got it for £1485/= (LCD + Blu-ray BDP-360)
I am spending too much for my wife! :mad: :suicide:
theraq
I am planning for that... htpc for bed room.. than I will swap things around.
BTW how about Sony VGX (round) media pc's are they any good?
Razor
Off topic:
I saw that same tv with the same package for £700.
:D Only joking mate, sorry I couldnt resist. :devil:
Congrats on your new toys mate. :smashin:
You could always take a dremel to a heatsink where the fins interfere with the memory. ;)
eiren
Haha :rotfl:
You could cut them off like Razor says, or even just bend them down. They are pretty flexible. I am sure those fins at the bottom edges don't actually take much of the CPU heat away themselves. Only looks like you'd have to do 2-4 of them at the most.
theraq
LOL nice one you nearly gave me a heart attack!
Razor
theraq
Thanks for case fan advice! these Noctua fan's are excellent!
:thumbsup:
Razor
theraq
Guys!
Can you advice about SSD is it too early to go for it?
Any pros and cons
Razor: your exp. with it?
I am looking for this for Windows 7. I mean want to have something good before I will clean intall it later this year. Right now using RC and I'm quite happy with it. Will 60gb will be enough for it? :confused::confused:
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
Latest News
Sky bringing Apple TV+ to Sky Glass and Sky Q customers
  • By Andy Bassett
  • Published
AVForums Podcast: 27th October 2021
  • By Phil Hinton
  • Published
Linn unveils latest Klimax LP12 flagship turntable
  • By Andy Bassett
  • Published
Samsung Tizen plans include cloud gaming for smart TVs
  • By Andy Bassett
  • Published
Freeview Play racks up 10 million users
  • By Andy Bassett
  • Published
