Raheel's HTPC + Gaming Machine (load's of pictures) and future updates...
theraq
Established Member
Hello,
(It will be long post with details, sorry for that)
I think I will start with my past experience, current and future plans. So here is my story.... past, present and future
Past:
I start... using computer when I was about (I think) 10 or 11 years old.... My first computer was 486DX2 with 4MB memory, 14" VGA Casper Monitor, 1.44 floppy, 512MB hard drive and a dot matrix printer. No sound card no CD-ROM. I remember we use to play Dangerous Dave, Prince of Persia and other MS DOS based games era.
Used to run applications (GW Basic etc) on MS DOS and then start using Windows 3.11. After that I used to upgrade my pc ever six months... Good old days!
About two years back I bought HP XW6400 workstation in an auction quite cheap about £450, dual Xeon dual core processors etc. In last few months I saw many great HTPC and gaming machines on AV Forums, so I thought why not build my own, totally customized as I want! (Thanks to all posts and experience sharing here on AV Forums for idea's and encouragement). So I sold it my HP workstation and planned for new one...
Present:
After few days doing research on "hardest thing to choose" HTPC case which can fit into my TV stand, match colour theme of room/AV equipment (otherwise I'd kicked out by my wife) and MOST important have enough inside space so I can put long graphic card and other items.
Future:
1) Microsoft Desktop Entertainment 7000 Bluetooth keyboard. (GOT IT!!!) "update 29 May 2009"
2) Do I need DVB/TV Tuner? Got Sky HD and Technomate HD 6900 already...
3) Processor cooler possible Mini Ninja (as suggested)
4) [-]Water Cooling Solution (worth it????) [/-] (not now :( )
5) Who knows the future?! will see! :) give me some idea... :lease:
Aim & Objectives:
1) Get the best computer components and fastest processor (of course not Extreme Edition!), which can play all recent games (most importantly FPS!) and can handle all multimedia files including High Definition contents.
2) Future proof (at least a year) and can upgrade easily.
HTPC details, reasons (why I choose particular item) and problems/solutions (if any)
***update***
Processor: Intel Core i7 950
Reason to buy: Well from day 1 I used Intel processor and had no issues whatsoever. That's why I go with new Intel i7. Upgraded from i7 920 within three weeks :) one of my friend bought it and got serious money issues, he sold his system but before that I offer him my processor with some cash in exchange with 940 :)
***update*** Now got i7 950 becuase my i7 940 was dead!
Motherboard: Intel DX58SO Extreme Series
Reason to buy: Again I used Intel boards from start (remember 440BX/BX2 board?). Sold build and most stable boards as per my experience that's why I bought this board.
Memory: Corsair Dominator DDR3, TR3X6G1600C8D - 6GB (3x2GB) PC3-12800 (1600)
Reason to buy: AS per many review's, found this memory is most stable and trustworthy and it is running fine at its full speed without any issues
Memory Cooler: Corsair Dominator Airflow Fan
Reason to buy: Just to make sure memory temperature will be stable all time.
HTPC Case: Silverstone LC20B-M Case with VFD and Remote (Black)
Reason to buy: Well after a long research, this is the only case that can fulfil all my requirements such as colour, remote, front display, covered CD-ROM & card reader area and height, due to height limitation I was not able to buy Silverstone CW-02, otherwise I'd definitely go for Silverstone CW-02.
Problems: Hard drive enclosure/case cause space issues, but I manage to install all things, first of all if you have long graphics card or with big coolers will be a problem. If you see in my pictures end of my card is in that enclosure. So MAKE SURE you card is not long and big enough that can't install in it. Other problem is that overall inside case is small (or you can say congested) so can be a problem if you will not install couple of cooling fans for HDD and for air flow, that's mean more fan more noise! (which is not a problem for me, but might me for others). In nutshell NOT an ideal case if you are looking for HTPC with Gaming machine like I do otherwise if you are looking just for HTPC with passive (e.g. graphics) solution than go for it!
Power Supply Unit (PSU): Silverstone 1200W SST-DA1200 MODULAR Power Supply
Reason to buy: Future proof, good reviews and good quality
Problems: It's Size! in pictures I thought it will be slightly longer than normal ones but it is too long/big and due to that I am unable to install any hard drive in that area of hard drive enclosure. (see in pictures)
Graphics Card: SAPPHIRE HD 4890 1GB GDDR5 PCI-E OC-Edition (connected to my LCD)
Reason to buy: Best card available right now with complete multimedia support including 7.1 sound over HDMI (NOTE: in under £200 price range)
Problems: None with this one but had two dead Gigabyte (GV-R487D5-1GD) 4870 cards (I'll never recommend Gigabyte to anyone) details are here
Hard Drive: 1TB x 3 SAMSUNG SATA2 HD103UJ 32MB (QTY. 3)
Reason to buy: Best in market right now. Already had one before for a year with not a single issues!
Hard Drive: 250GB SEAGATE ST3250824AS Hard Drive SATA2
Reason to buy: Gift from Friend
Hard Drive: 80 GB SATA2 Maxtor STM380215AS DiamondMax 21 Hard Drive
Sound Card: Creative SoundBlaster X-Fi Titanium Fatal1ty Professional Pci-Express
Reason to buy: This card is from my old machine, well my main reason to get this card was to pass 5.1 sound over optical and future proof. So for that this card tick all the boxes.
Hot Swap Enclosure: Icy Dock MB-672-SKGF-B Silver Mobile rack for 3.5" SATA HDD, LCD, easy swap trayless
Reason to buy: Just want internal hot swap option :) or if I am unable to install another hard drive inside the case.
External Hard Drive Option: Sharkoon SATA QUICKPORT DUO USB and eSATA (For hot swapping)
Reason to buy: Well, able to connect laptop and regular SATA drives and future Sky HD hard drive upgrade plan. I will recommend this fast if you use eSATA ports, I know bit costly but I found it quite useful for Sky HD upgrade and regular use..
Blu-Ray/HD-DVD / DVD Writer: LG GGC-H20L Lightscribe SATA 16xDVD±R +RWx8/-RW x6 - Blu-Ray & HD Disc's black - Retail Box
Reason to buy: Birthday Gift from Friend :)
Card Reader: Scan (Realtek) 81-in-1 3.5" Internal All-in-One Card Reader + 1xFront USB Port
Reason to buy: Cheap and can read all card types. Must have in HTPC in my opinion.
Skype Speaker: US Robotics USB Internet Speakerphone Model: USR9610
Reason to buy: Gift from scan, otherwise never buy this.
Case Cooling Fans: 80mm Coolermaster Silent Internal Case Fan with Blue LED Quiet 22db (S82-EB) - (QTY. 3)
Reason to buy: Need some good quality fans for (two) CPU exhaust area and (one) in hard drive area.
Case Cooling Fans: Hiper 80mm Case (thin) Fan (QTY. 2)
Reason to buy: I need THIN fans less than regular 25mm, this fan is 18mm and quite. I installed one next to memory exhaust area and on top of sound & graphic card for air flow.
More Case Cooling Fans: : 2 x 80mm Noctua NF-R8 Quiet Case Fan & 1 x Noctua NF-B9-1600 Vortex-Control 92mm Quiet Case Fan
Reason to buy: Best air flow fans out in market... Thanks for Suggs by friends/members on this fourms...
Webcam: Logitech Webcam Pro 5000
Reason to buy: Another gift from Friend :)
Mouse: Logitech Air Mouse
Reason to buy: Stylish and can use in AIR! very useful if you sitting far from your LCD or if there is no table/mouse area next to you.
Keyboard: Wireless Entertainment Desktop 7000
Reason to buy: Light weight and bluetooth + mouse touch pad on keyboard!!!
Bluetooth Connectivity: Bluetooh USB Device
Reason to buy: Quite old dongle, used to connect other Bluetooth devices such as Pogo, Sony wireless photo printer and mobiles etc.
Infra Red: Bafo BF-120 Sigma Tel InfraRed USB Device (for old mobiles etc)
Reason to buy: Quite old dongle, can be useful for old mobiles and PDA devices.
USB Card: Startech 5 Port PCI Express USB 2.0 Adapter Card
Reason to buy: A good reason behind this card. Mainly for internal USB and extra front ports
Problems: (Recommended solution) As we know there are only two USB headers on most motherboard and some have only one. And these days most of internal card readers and front USB ports requires internal headers in HTPC cases. To resolve this (in my scenario I need two more internal USB headers for my front Display and USB ports so in total I required 4 headers or 7 USB ports) so I bought internal PCI-Express card (again future proof) and install all front USB ports cables to this card (you can see in pictures) by using below mentioned cable.
Internal USB to External USB Cable: Internal/external USB 2.0 cable (USB-A to 5 Pin Header) (QTY. 2)
Reason to buy: As mentioned above and will recommend this solution instead going for any modifications (cut/joints) to your existing USB cables.
iPhone Dock/Sync: iPhone USB sync/charging Dock (freebitsuk.co.uk) (Thanks to "Cocacola" for advice)
Reason to buy: Need some permanent solution for iPhone other than their white cable hanging around.
Cables / leads​
SVGA Cable: Belkin PureAV™ Super VGA Home Theatre Cable
Reason to buy: (Recommended and Must have) Believe me I was using 3rd party regular SVGA cable after upgraded to this cable I can defiantly say HUGE difference in colours and no more blurriness.
HDMI: QED Qunex HDMI-P HDMI to HDMI Cable (2m)
Reason to buy: Had this cable in spares. So I used to connect my HTPC via my Denon amplifier, for watching High Definition contents etc. Not fully tested yet.
Optical: Profigold PGD563 TOSLink Optical Cable (3m)
Reason to buy: For my Creative Sound Card to my Denon for 5.1 sound.
[-]In Last Operating System: Windows Vista Ultimate 64 Bit :thumbsup:
Reason to buy: Another birthday gift... my friends know what I want... lol[/-]
New Operating System: Windows 7 Ultimate 64 Bit :thumbsup:
Overall Problems
Well, I had blood boiling moments when my processor died and "twice" Gigabyte graphics card died. Other than that as I already mention about inside space of case... I struggle a lot to put things together and make it clean as possible as I can keeping maximum air flow. Other than that "touchwood" everything running smoothly.
Thank you for your time and pictures are coming in next posts... :smashin:
(Please note you might not have same reasons or believes about these items, so advice and comments are most welcome in constructive way because I do not want to start any brand war here like nVidia v/s ATI or Intel v/s AMD. I bought these items because I think they are best for me and fulfil my requirements. Sorry!)
theraq
Established Member
Pictures Set 1:
All items arrived from Scan!
Item's in a box
PSU and other boxes
SilverStone LC-20M from front
SilverStone LC-20M from top
Silverstone LC-20M Case Back
Silverstone LC-20M Case Inside
theraq
Established Member
Pictures set 2:
Silverstone LC-20M Case Apart, due to rewiring of front port cables.
Silverstone LC-20M Case Apart, due to rewiring of front port cables, picture 2.
Hard Drive enclosure fans installation (by my friend Alitech)
Another picture of ard Drive enclosure fan
Case Exhaust Fans
Case Exhaust Fans from outside
USB Multicard Reader
theraq
Established Member
Pictures Set 3:
Motherboard and other boxes
PSU
PSU Closeup
PSU Installed in case
PSU in case back view
Motherboard and other items in case now
Ahhhh!!!!!!!! need to take out PSU due to installation issues
theraq
Established Member
Pictures Set 4:
All in (wires mash)
Wires mash 2
That's more like it (wires sorted)... front ports
Front Panel Closeup
Icy Dock MB-672-SKGF-B Silver Mobile rack for 3.5" SATA HDD, LCD and LG GGC-H20L Lightscribe SATA 16xDVD±R +RWx8/-RW x6 - Blu-Ray & HD DVD
Icy Dock MB-672-SKGF-B Silver Mobile rack and LG GGC-H20L (closeup)
theraq
Established Member
Pictures Set 5:
Forget to mention before Memory Fans was also replaced due to buzzing noise
Top view without memory air cooler
Memory Air cooler back on
Gigabyte ATI 4870 GV-R487D5-1GD VGA Card (dead and returned "twice")
Fan Connector and Creative Soundblaster X-Fi Titanium Fatal1ty Professional Pci-Express (not a clear pic)
Stickers!!!!!!!!
theraq
Established Member
Pictures Set 6:
My new Sapphire ATI HD 4890 OC 1GB!!!!!
CD's with new card
New card installed top view
Card Closeup
Sapphire ATI HD 4890 OC Connection and other Cables
Sapphire ATI HD 4890 OC Installed 4 (Back View)
theraq
Established Member
Pictures Set 7:
Another Sapphire ATI HD 4890 OC Installed (Top View)
Case in the stand 1 :)
Picture 2
Picture 3
ATI 4550 best friend during Gigabyte RMA's
Sharkoon SATA QUICKPORT DUO USB and eSATA with 80 GB SATA2 Maxtor Hard Drive (Gift from Friend)
theraq
Established Member
:lesson: !!! Front USB to Header Solution !!!
As I mentioned Startech 5 Port PCI Express USB 2.0 Adapter Card (for internal USB and extra front ports) 2 (Good solution for those who have one or only two USB headers on motherboard but need more for front USB ports or USB internal card reader)
This is the cable I used for connecting front USB ports to that card
Call cables connected here
If you need any further details please do let me know! :thumbsup:
theraq
Established Member
Few More Pictures:
Webcam
Keyboard Mouse
2 x new Hiper Thin fans
2 x new Hiper Thin fans (unpacked)
Fan installed
Fan Installed
Both new fans
theraq
Established Member
Case Display Closeup 1
Case Display Closeup 2
Windows Vista Ultimate SP2 Index Rating
Off topic: Vaja Limited and Ivolution SP Cases :devil:
theraq
Established Member
That's all for now... will update more pictures in future...
Thanks for your time and as mentioned idea, suggs and comments are most welcome.
Thanks!
:thumbsup:
andyUK101
Ive got the same case and had the same problems with the HDD cage and space - and my PSU is a lot smaller
I also found that the SATA connections for the HDD were directly underneath the HDD cage - when the HDD cage is locked in it puts a lot of pressure on the SATA ports and one of mine has bent - cant see if this is a problem for you from the pictures
Nice build and pics
mikes
Fantastic build, great pics and would be a superb gaming machine but major overkill for a HTPC, you just don't need that spec of component.
With all those fans, how noisy is it? HTPCs need to be as quiet as possible.
Razor
kalababa - Nice pics mate and good to see more gaming HTPCs being made and used. Keep up the good work fella. :thumbsup:
theraq
Established Member
Nice build and pics
Thanks! :thumbsup:
And yes it is a problem but thankfully Intel sent angled SATA cables which helps a lot
Cable look like this
If I used the regular ones than I even can not install Graphics card properly due to its big cooling fan and case.
So suggs. if you are going to buy this case than buy these SATA cables too, will help's a lot.
theraq
Established Member
Thanks!
I know it is bit over kill for HTPC but as I mentioned it is Gaming + HTPC that's why these high specs....:smashin: About fans these are quite fans and not too loud overall also I'm next to Wembley Stadium so there is lot's of noise every day.... :mad: so I'm bit use to with noisy environment... as I mentioned may be it is not loud to me but for other it might be quite loud.... :confused:
Thanks!
homethx
Established Member
nice htpc !
Why are you using a 1200 watt psu over kill :eek: have you ever worked out how much a real world PC uses ?
theraq
Established Member
:lesson: Silverstone LC-20M and BIG CPU Coolers issue
There was one more issue with SilverStone LM-20M case, if you want to use CPU cooler such as Zalman 9900 LED or Cooler Master V8 in this case... FORGET IT! :suicide:
I ordered Zalman 9900 LED and when start to build my machine I found out we can not install any "good n big" CPU Coolers. Due to case height after mother board installation.
The only option I found (as advice on this forums) is Ninja Mini CPU Cooler.
So any CPU cooler more than 115mm (in Height) will not fit in this case :mad:
I myself didn't tried it yet (Mini Ninja) but will order it or borrow it soon to test. Will let you know if it will fit in this case without any issue... :rolleyes:
Theydon Bois
Very nice, and thanks for all of the pics, very well detailed indeed. :smashin:
I will add a link to the gaming build threads.
theraq
Established Member
Just for an update, I am testing different Media Centers, will post pictures soon. So far many issues with 5.1 audio out and picture settings in them (jerk effects, not smooth play back)
Thanks.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
