Rage 3D Tweak
Discussion in 'Desktop & Laptop Computers Forum' started by tbrar, Aug 31, 2003.
  1. tbrar
    tbrar
    May 31, 2003
    609
    16
    Rage 3D Tweak............ what is it and what will it allow me to do ?
    Phil from Uvem will be installing this on my HD prior to delivery of new HTPC and I wondered what it was.
    It being a Sunday, me being impatient, I thought I would post to find out.
    Tony
  2. tbrar
    tbrar
    May 31, 2003
    609
    16
  3. Assesears
    Assesears
    Used for overclocking your card,various different screen resolution modes and settings.
  4. tbrar
    tbrar
    May 31, 2003
    609
    16
    Assesears
    Thanks for the reply.
    Excuse me as I am new to this.
    Could you kindly expand on what you mean by various different screen resolution modes and settings, as isnt this what Power Strip does ?.
    Tony
  5. Assesears
    Assesears
    The extra screen resolutions are custom ones. If you check in display settings you can only select a few resolutions with Rage 3d you get the lot. The settings are for tweaking anything on your card i.e open gl,direct3d,colour settings games and benchmarking.In display settings you can only play around with a few. Most folk I know only use it for overclocking, not to sure about the custom resolutions I never used them. There are many different tweak programs around for graphics cards rage3d and powerstrip are the popular ones.
  6. tbrar
    tbrar
    May 31, 2003
    609
    16
    Great, Thanks. :smashin:
