Radiator sizing help
Discussion in 'General Chat' started by KW1816, May 12, 2005.
  1. KW1816
    KW1816
    Jun 14, 2002
    770
    Surrey
    +14
    Without sounding too thick ;) how do you measure a radiator ??
    We've got an old radiator we want to replace and quite fancy a 'designer' one from B&Q. Unfortunately they don't carry stock so I can't go down with my tape measure, So how do you measure one ?
    Are they all standard sizes ?
    Do you measure the actual radiator or the gap between the valves ?
    What's the 'pipe centre' measurement all about ??
    :lease: :lease:
    Ta
    Kevin.
  2. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    A common size is 900mm high - length you will have to measure it i'm afraid.
    Pipe centre is the point in the centre (surprisingly) where your valves will enter the rads.
  3. KW1816
    KW1816
    Jun 14, 2002
    770
    Surrey
    +14
    Length is the measurement I need - is it the length of the rad itself or the distance between valves ?
  4. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Measure the length of the radiator.
