Radeon drivers - help please !!
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Jun 24, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    I have a Sapphire Radeon 9000 VIVO graphics card and every time I load a new set of drivers for it Windows XP then finds some new hardware. There are 2 unknown hardware items found (location on the Radeon 9000 card) and I usually end up telling XP to ignore this.
    This is probably something to do with the VIVO part but I'm not sure if I need to download another driver... and if I do where to get it from.
    Hope someone can help - thanks
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    nope - thats normal. it happens on my r9500 aswell.windows see's the dual display output as two seperate cards. Totally normal and as long as you install the drivers correctly, nothing to worry about.
  3. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    Hi James - I do have the 2 Radeons installed but I also get "unknown hardware" detected as well.
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
  5. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    I've just installed those drivers tonight and it still finds the unknown items.
    Here is a screenshot of the devices:-
    Hardware devices
    This is what I get when I open the properties of the unknown devices:-
    Unknown devices
    This says that it is on the Radeon 9000
  6. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    +286
    Did you erase the old drivers before installing the new. You do this in the remove/uninstall software in the control panel. Also did you disable your antivirus software when installing the drivers. This can sometimes cause issues if not dissabled before installation.
    Also check within the settings within the display in the control panel. Hit the advance button and look in the adapter tab. You should see the radeon 9000 listed. Also did you down load the control panel as well?
  7. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    I didn't realise you had to uninstall the old drivers 1st - I suppose I should read the instructions next time :blush:
    Thanks for the help - I'll give it a go when I get home tonight
  8. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    I still didn't get it working and still had the unkown devices........
    Until now !!
    I've just loaded the new Catalyst 3.9 drivers from ATI and they loaded fine and now there are no unknown devices. The 1st time in over a year I've got an ATI driver to load properly :)
  9. Kramer
    Kramer
    Possible/probable that "Hydravision" was required for the "other" devices - I assume the VIVO "devices".
    Hydravision isn't part of the standard drivers but is included in the driver "pack" - 25mb approx IIRC.
    You've got it sorted now so irrevelant.
    :smashin:
