Radeon CatalystDrivers
Discussion in 'Desktop & Laptop Computers Forum' started by Jazz Monkey Jr, Jun 7, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I am trying to install the latest radeon drivers for my laptop, it has a raeon 9700 in it.
    The problem is that I installed radlinker drivers a while ago and the ATI install didnt recognise it.
    I tried to just install standard VGA driver but it only gives me options for ATI Omega drivers.
    When I run the install for the 5.5 drivers is comes up with the error:
    INF Error
    Video driver not found
    Any help?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I am not sure what support ATI provides for laptop drivers. I know the driver is called a 9700 but you may be better served going to the laptop manufacturers website for a working driver. If the catalyst drivers should work then use the ati removal tool to completely clean the laptop of any previous drivers and restart, declining the laptops offer to install drivers for the display adaptor. Then install the catalyst drivers.
  3. SMooV
    SMooV
    Mar 2, 2005
    23
    4
    Tayside
    I have encountered this problem installing drivers (both ATI and Omega) for a 9550. having scoured the net at the time the advice seems to suggest that to resolve this you should:
    • Uninstall any previous graphics card drivers (ATI or otherwise).
    • Delete any ATI related entries in your registry that have been left.
    • Install your graphics card using the Operating Systems Standard VGA Drivers.
    • Install your chosen Radeon Drivers.
    I have also encounterd a further severe error "zero display service error" during driver installation and have still not been able to resolve it. There are a lot of references to it on the net, but no real solutions to resolve the error. If anyone knows how I can around it I would be glad to hear from them.
    Si
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I have sorted it, I downloaded some different drivers, I sis a search for mobile 9700 driver and got some different ones.
    If I am outputting to a plasma display, I can just set the resolution to match that of the plasma (1024x768), which refresh rate woud be best?
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Plasmas are usually 60hz native but will accept 75hz to cater for PAL dvd's.
