radeon 9700
Discussion in 'PC Gaming & Rigs' started by steevs, Feb 8, 2003.
  1. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Hi guys
    I just got a radeon 9700, how do I tell if its a 9700 or a 9700 pro, are there are any programs that would tell me that . thanks in advance.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    It would most likely say on the packaging or invoice. You can go into Control Panel - System. Look for a button/tab called Device Manager (depends on what OS you have) and look for display adaptors, in here it will tell you what you have.
    How much did you pay for it, the 9700 is significantly cheaper than the Pro.
  3. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    I paid £220 for it second hand on the understanding it was the pro, now i'm not so sure it is, in display properties it just says radeon 9700 series.
  4. Garrett
    Garrett
    Apr 21, 2001
    40,282
    2
    167
    The best thief you’ll never see.
    +6,682
    Don’t panic it may come back that even if you have the pro.
    Has the pro got more memory i.e. 128 instead of 64? what make of card is it? And can you go to the manufactures site to see if there is a difference in the pictures between the two of them, if so you can check your car that way.
  5. Garrett
    Garrett
    Apr 21, 2001
    40,282
    2
    167
    +6,682
    Does going in this way get you more information???
    Try right clicking on the desktop, in display properties choose, Settings, Advanced and on one of the tabs may say what card you have.
  6. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,558
    7
    167
    Birmingham, UK
    +10,393
    I have the 9700 Pro and the Adapter Type is reported as
    RADEON 9700/9500 Series
    Chip type : RADEON 9700AGP (ND)
    DAC Type : Internal (400MHz)
    Memory Size : 128Mb
    Bios Info: 113-94206-101
    Hope that helps.
  7. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Yep, thats the same as mine.
    cheers spectre.
    Thx for your help guys.
    Steve
