Radeon 9700 Pro and overclocking
Discussion in 'PC Gaming & Rigs' started by jmjm, Jun 16, 2003.
  1. jmjm
    jmjm
    Could someone give me some info about overclocking a Radeon 9700 Pro?
    I also need a TV card - would I be better off swapping to an all in wonder or a separate card?
  2. Kramer
    Kramer
    My Sapphire (early model, actual ATI card) OC'ed very well.
    IIRC, the GPU did 370 no probs with the stock cooler. Mem did 350ish (700DDR).
    Watercooled it a few days after I got it (DD block) & ram-sinked the memory.
    Been @ 415/370 (or 415/740 - ddr) since (6 months) without any problems. Benchs @ 430/770 :eek:
    I use Powerstrip to overclock (need it for custom resolutions for PJ anyway) & recommend it.
    Better (IMO) to get a separate capture card but depends what you want to do I suppose. IIRC, AIW cards don't work with Dscaler - THE best app for PQ improvement from a capture card.
  3. Peace
    Peace
    i have a 9700 np and i can get my gpu to pro speed but not my memory because i have the slow 3.3ns one.
    maybe you have to flash your bois to be able to overclok but some cars like saphire don't need to be flashed.
    I use Rage3D Tweak to overclock my card and it works well.
    Good Luck
    Peace
