Radeon 9700 Pro and Barco 1208/2
Discussion in 'Desktop & Laptop Computers Forum' started by nfordenfield, Mar 29, 2003.
  1. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Has anyone experienced this, i've posted a CRT version of this post on the CRT section, but this is to do more with the suspect graphic card and or software set up.
    Since is used loaded the windows rpc software and region killer, I seem to have a side effect of a rolling screen when viewing dvd.
    The whole image stability is jumpy when moving the mouse.
    Any ideas where to look? The image is totally stable on the monitor.
    The only other possiblity is the vga breakout cable.
    Rgds
    Nathan
    p.s. Just when I had everything working, am too much of a tweaker for my own good.....................
  2. John DB
    John DB
    Jul 29, 2002
    344
    +7
    Hi Nathan,
    My 1208/2 would roll the picture when using port 5. It was solid as a rock on the windows desktop but as soon as you started a dvd then occasional rolling would occur.
    I fixed it by using an extron interface to boost the output.
    A couple of months later I tried using port 3 direct from the PC purely out of curiosity and it was a far better picture! No extron required :)
    Regards,
    John.
  3. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Just watched an episode of stargate sg1 using Dscaler and the picture was rock solid.
    Must say that this is a fantastic pic.
    I'll have to try an extron or go the port 3 route - more money.
    Where did you get thje port 3 cable from?
    Thanks for the reply.
    Rgds
    Nathan
  4. John DB
    John DB
    Jul 29, 2002
    344
    +7
  5. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Well just when it was safe to get back into the water.............
    If the actual XP loading screen is jumpy, does this single out the graphics card?
    Seems now not to even sync on a monitor, hope the Graphic card has not duffed the monitor as well!!!!!
    Any ideas?
    Rgds
    Nathan
  6. John DB
    John DB
    Jul 29, 2002
    344
    +7
    It doesnt sound good :( Have you tried using a different cable to your monitor or re-seating the graphics card in the m/board? If they don't solve it then try the card in a different pc before returning it.
    As you say a jumpy winxp loading screen does rule out a rpc/region killer/powerstrip or other software problem.
    Good luck, keep us informed.
    John.
  7. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Well, it maybe the bios.
    I reset the bios back to factory settings, when it will only recogonise the 2400+ as a 1800+ (100mhz setting) and no screen roll, well only a very little on one game when changing settings which I can live with.
    Theatertek works fine and so does Dscaler.
    So I'm going to read up on AMD website about new bios settings and see if anyone else has similar probs.
    rgds
    Nathan
