Radeon 9600 diagonal lines
Discussion in 'Desktop & Laptop Computers Forum' started by Clint C, Dec 28, 2003.
  1. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Chaps
    Seems clear to me that I should return the product but I thought I'd ask the question. Has anyone experienced via s-video from the above card an output which seems to have diagonal lines flowing through it from bottom left to top right? The picture from a distance looks fine but when you look up close it's definitely there. I haven't tried it through a regular pc monitor yet, only to my Sony tv which displayed it fine when I've used a Radeon 9000.
    Return the product for a replacement or is there an easy fix?
    Any more info required let me know.
    Clint.
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Can you try the 9200 in there to eliminate everything else? If the 9200 doesn't do, but the 9600 does, then it's got to be the card.
    It sounds like some kind of interference though.
    Gary.
  3. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Gary
    I don't have a 9200, the 9600 was just as an upgrade for me to include a DVI connection. I still have my old 9000 and since switching them back the 9000's picture isn't flawed in the same way.
    Clint.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Oops, yeah - I meant the 9000. :)
    Well, you've eliminated everything else I think by switching the 9000 back in, so it looks like a new card is needed just as you suspected. Which 9600 is it? I have the Saphire non pro which seems to work well.
    Gary.
  5. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Yeah, you've got a point, it could be the make but I can't believe they'd all be like that. I have the Connect3D 256MB one.
    Clint.
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    I don't think they'd all be like that either to be honest, I was just curious as to the make.
    You going to get it swapped for another one?
    Gary.
  7. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    Yeah, hopefully, as long as they don't see there's a problem swapping them I'll be sticking with the same card.
    Clint.
  8. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Good luck - hope it goes without a hitch. :)
    Gary.
  9. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +174
    Have you tried a better s-vid cable?
  10. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    My SVid cable isn't a cheap one and it worked perfectly fine with the previous Radeon 9000... :confused:
  11. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    clintc, if you s-vid cable is decent then this sounds like it might be a ground loop issue. Try disconnecting everything from the TV apart from power and the PC. You might also want to try running a ground wire from the PC chassis to a ground point on the TV (e.g. the outer terminal on the RF aerial input).
    MuFu.
  12. Clint C
    Clint C
    Dec 10, 2002
    420
    Wiltshire UK
    +4
    :D Thanks MuFu, I wouldn't have expected anything less from you... :D
    savastore have agreed that I can send it back so I'll be doing that on Monday... but I'll certainly give your suggestion a try should they say they can't find anything wrong with it. :smashin:
  13. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Surely, if it was a ground loop issue, it would do it regardless of the graphics card?
    Gary.
  14. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    That's what I would have thought as well, but different cards seem to be susceptible to different degrees (as they are to EMI, which might also be part of the problem). There are numerous examples of this type of thing on Rage3D forums - diagonal lines, ghost lines, wavy lines etc.
    Actually it might not be a loop, as such - SVHS has discrete grounds for Y & C and it could just be noise on those planes that's causing it.
    MuFu.
  15. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Ah - thanks for pointing that out. :)
    Just goes to show how theory and practice can be two very different beasts.
    Cheers.
    Gary.
