Radeon 9550 any good for HTPC?
Discussion in 'Desktop & Laptop Computers Forum' started by Rob100, Aug 23, 2005.
  1. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    I am just planning to build a second HTPC (for use with PJ). My current set-up to my Plasma is using a Radeon 9600 non-pro as I wanted a fanless card.
    The new HTPC will have to "work harder" on the PJ due to higher res (1280x720) so I'll be using my "old" 2.8 NW P4 (possibly O/C'ed to 3.56 as it is at the moment).
    Main uses for HTPC are playing DVD's using MPC, NVidia DVD Codec and ffdshow. Also used with SweetSpot and DScaler for external sources.
    Would a Radeon 9550 be up to the job? There doesn't seem to be many 9600 non-pro cards available now, but Connect 3D do a fanless 9550.
    If the 9550 isn't up to the job then what's the next best thing? Everything seems to have fans!
    Thanks,
    Rob.
  2. The Dude
    The Dude
    May 21, 2004
    6,352
    Beverley, East Yorkshire
    +2,720
    can't answer your questions, but my 9600Pro is definitely fanless, I'm pretty sure that's a 3DConnect model...?
  3. DaveP
    DaveP
    The next best thing is my 9600Xt with a zalman passive cooler fitted!
    click here!
    Dave
    PS, If that is too big for your case, I could consider keeping it and selling my 9200SE which has DVI, VGA and s-video output and is air cooled.
  4. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Get one of these cards...
    LINK
  5. Rambles
    Rambles
    Jul 14, 2004
    8,495
    UK
    +1,357
    Don't forget the forum favourite Gigabyte fanless 6600GT and nvidia purevideo codec.... ;)
  6. Skunkpipe
    Skunkpipe
  7. roninsrv
    roninsrv
    I'm running a 9550 (with fan) and the performance is fine. Minimal stutters and funning fddshow with dscaler. The 9550 can be OC'd quite a bit.
