Radeon 9000 pro help seting up
Discussion in 'Desktop & Laptop Computers Forum' started by wynouk, Dec 15, 2002.
  1. wynouk
    wynouk
    I'm looking for advice on how to set up my tft monitor and my panny 100e projector on my Radeon 9000 pro so i can view the panny at low resolutions and the tft at high, for now it's either high on or low on both and i've also noticed that when i go into the 10 pin bowling game in win xp that the graphics are crap the game works very slow with large pixels.
    I've loaded the drivers in ok so i don't understand it.
    any help with this would be great thanks.:confused:
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I don't believe you can run a Radeon at multiple resolutions, the best you can do is use something like powerstrip to allow you to switch resolutions very quickly.
    Jeff
  3. wynouk
    wynouk
    Where can i get powerstrip and is it any good??
    Is there any known problems with winxp pro and drivers for radeon 9000 pro that causes my graphics to under perform
    ie: slow game play and large pixels??
  4. wynouk
    wynouk
    bump
  5. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,772
    Outpost 31
    +215
