Radeon - 9000 or 7500?
Discussion in 'Desktop & Laptop Computers Forum' started by owain_thomas, Jan 6, 2003.
  1. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    I am still researching my first HCPC setup and have always thought I would get a radeon 9000pro, but it occurred to me today that maybe a 7500 would be ok for my needs.
    I don't want to play games on the computer, it'll just be for DVDs, DIVXs, CD playback, Showshifter and internet access. Do I need the extra cost and - more importantly - the extra fan noise of the 9000 or will the 7500 do everything I need?
    Owain
  2. Dangerous
    Dangerous
    The 7500 also has a fan but I can't say that it’s particularly audible. I use the card in my pc exclusively for DVD viewing and it performs very well especially as it is supplying an image to a 10ht on an 8 feet screen.
    Dave
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    Oh right, I thought it was fanless, maybe that's the 7000 then.
    Can any one outline the differences between the 7000, 7500 and 9000 as far as using in a HCPC goes, I'm not concerned about 3D performance at all.
    Owain
  4. halephil
    halephil
    May 24, 2002
    61
    Hi, based on your requirements I'd recommend a Sapphire Radeon 9000 64MB (not the Pro version) - the dual head version with DVI is fanless and around £50. It is supported by Rage3D Tweak (unlocks several resolutions) and Powerstrip (if you need unusual resolutions).
    cheers, Phil
