I've reduced the thermostat on the radiator to 1 but it still stays at the same temp as max. How does a thermostatic valve work does it stay hot until the valve shuts off or does it let in less hot water so the rad is colder?
I would prefer the rad to be slightly warm, just for the rooms that are unused.
Does it sound like the thermostatic valve was put on the wrong side? How can you tell?
