r63 black arrow problems
Discussion in 'General Video Gaming Chat' started by derekrcross, Aug 24, 2004.
  1. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    had major problems tonight first of all load up problems then get kicked of after 5 mins from live is it just me :mad:
  2. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Its just you :hiya:
    Sounds like all that Dust on the xbox from lack of use :rotfl:
    Have you checked your xbox connections Press Y on the connect screen - the MTU,ICMP and NAT ratings should all be 1 if not then you will need to alter your settings on your router
  3. mattkbishop
    mattkbishop
    It's not just you mate, there are LOADS of problems on it. Check out the problems thread by the Developers here.
  4. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    thanks seems alot of people are having problems :mad:
  5. -Spike-
    -Spike-
    May 17, 2001
    1,585
    E.Sussex
    +287
    Thought you sorted your problems Del?
  6. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    well last night played with router and it worked all night so im none the wiser why it happens during the week
    strange thing is even when mine was kicking me off live the xbox up stairs is fine :rolleyes:
