R4 or R1 Mummy Returns?
Discussion in 'Movie Forum' started by GarethH, Aug 29, 2001.
  1. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    I am still debating on whether to buy the R4 or R1 version of Mummy Retruns. The R4 has a DTS track! However, i'm still not sure that the picture quality might be comprimised! I'm pretty sure Movietyme were doing the R4 version, but i can't seem to find it anymore. Any Ideas?
    Which one are you ordering and where are you ordering it from?
  2. Guest
    Ezydvd (www.Ezydvd.com.au) have got R4 with a release date of 3/10 and a price tag which should convert to about £15.
    This review of The Mummy Ultimate Ed makes ref to slight dissapointment with transfer quality - whether Returns will be same?
    <a href="http://www.michaeldvd.com.au/Reviews/Reviews.asp?ReviewID=64" target="_blank">http://www.michaeldvd.com.au/Reviews/Reviews.asp?ReviewID=64</a>
    Cheers<br />OG
