R4 DVDs
Discussion in 'Blu-ray & DVD discs' started by venablesphil, May 9, 2005.
  1. venablesphil
    venablesphil
    Apr 10, 2005
    158
    16
    Hertfordshire
    Hi probally in the wrong section but the bargain forum has become my second home. Basically I have just been updating my DVD profiller and I noticed that alot of my DVDs are R2 and R4. Does this mean that I can buy R4 dvds and they will work on my R2 player? Or are they all just same?
  2. Aretak
    Aretak
    Sep 25, 2004
    979
    +88
    No, it means that they're dual-encoded for both regions. Many, many discs from both the UK and Australia are R2 and R4, simply because that way they can sell the same disc in both territories (since we both use the PAL system).
  3. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    What he said - you would still need a multi region player to play a R4 only disc.
  4. SKippy
    SKippy
    I'm sure I've played region 4 on a region 2 player... I was under the impression they were the same aswell... I will have to investigate my collection now :rolleyes:
  5. Aretak
    Aretak
    Sep 25, 2004
    979
    +88
    Why would R2 and R4 be the same? There'd be no point in them being two seperate regions if they both worked on the same players. Most discs will only list one region or the other on the cover whether they're dual-region or not, so if you played a R4 disc on a R2-only player then it was likely dual-encoded for R2.
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    My friend is an Aussie who has had films sent over from Oz and they are region 4 which play on a region 2 machine no problem.
    Pete.
  7. lsuk
    lsuk
    Iv put R4 dvds into a R2 only player and they played ok :thumbsup:
  8. domtheone
    domtheone
    Nov 23, 2004
    14,777
    Nottingham
    +3,557
    Most do, since their dual coded.
    Some R4 discs (definately had some from Village Roadshow in the past) are coded for R4 only and won't play on R2 only machines.
    Can only think of Miss Congeniality as 1 example at the moment though!
  9. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,767
    2
    In a secret location with Jennifer Lawrence
    +9,565
    Moved to other DVD topics forum.
  10. lurker75
    lurker75
    While some region 4 DVDs are dual encoded with region 2 do not expect all region 4 DVDs to be compatible. I recently purchased Farscape box-sets which are only region 4 but luckily for me I'm multi-region compatible.
