R2 picture problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by tiberious, Mar 31, 2003.
  1. tiberious
    tiberious
    This is the problem - there is an area about 5 inches down from the top of an 8ft wide screen, about 2 inches deep, which flickers.
    If looking at vertical lines going through this area, the effect is like a comb - the line jitters from side to side.
    This ONLY happens with R2 1.78/1.85 ratio dvds. R1 dvds of the same ratio are fine, as are 2.35 ratio films of all regions.Happens on S-VID and Component cables.
    Anybody help ? - could it be as simple as cleaning the dvd lens ( although it has only played about 10 films) - or is it more involved.
    Anybody else witnessed his effect ?
    - oh, by the way - can`t see the problem at all on a 32" TV !
    Equipment - Tosh 900e , Sim2 HT300+ , dENON 3802.
    Grateful thanks in advance !
  2. Gary Nash
    Gary Nash
    Dec 15, 2002
    338
    Dorset
    +17
    Steve,
    I've encountered exactly the same problem. OWL recommenended I switch the video mode from 'normal' to 'vcr1'.
    Works fine for me, shimmer completely gone. VCR1 (or vcr2 mode with v2.13) work fine with ntsc R1 discs as well, so you may want to use this as your default setting.
    Gary
