R2 Gladiator
Discussion in 'Movie Forum' started by Dirk, Dec 27, 2000.
  1. Dirk
    Dirk
    Just bought the region 2 version of Gladiator. The picture is stunning, but I consider the sound, even the DTS sound not particularly valuable. The movie sounds very compressed. I have the same problem with the region 2 version of Saving private Ryan, while simple r2-discs like The green Mile sound perfect.
    I wonder if the region 1 versions of the first two movies sound better.
  2. bradavon
    bradavon
    I have had no problem with the R1 version of Saving Private Ryan it sounds very impressive (I do have the DTS version though).
