R2 Apocalypse Now Redux specs.
Discussion in 'Movie Forum' started by Jack Ryan, May 11, 2002.
  1. Jack Ryan
    Jack Ryan
    Apr 9, 2002
    37
    Basingstoke, Hampshire
    A friend very kindly bought me a copy of Apocalypse Now Redux R2. Being the sad anorak I am I had been thinking of getting the nicely packaged version that I have seen in some stores, including Virgin, and not others. Having scoured the web I have noticed 2 things. Reviews seem to say
    1) The ratio is different, 2.35:1, to that on my case, 2.00:1,
    2)The certificate on my copy is 15 whereas all over the place I see that it is an 18.
    Have Tesco got a different copy?
    Interested to to know what everyone else had got on their copies.
    Jack.:confused:
  2. Ron240
    Ron240
    Jan 3, 2002
    3,617
    Kirkcaldy (but i'm not a Fifer)
    +466
    The aspect ratio on the case is(i assume) correct and it is a 15 certificate.Every place that you have seen it listed as an 18 is wrong. I posted a thread on exactly the same subject a couple of weeks ago after i bought my copy from Tesco.
  3. Jack Ryan
    Jack Ryan
    Apr 9, 2002
    37
    Thanks Ron. Best I pay more attention to your threads next time!!
    Jack.
  4. Ron240
    Ron240
    Jan 3, 2002
    3,617
    +466
    No problem Jack. There are so many posts and so much information on this forum that all you have to do is miss one day and there is a lot to catch up on.If there is something specific that you want to know then try using the search feature at the top of the page.Just type in a keyword and you will usually turn up something.;)
