R1 vs R1
Discussion in 'Movie Forum' started by Rickster, Dec 22, 2000.
  1. Rickster
    Rickster
    Dec 22, 2000
    5
    London
    Does anyone know if American R1 DVDs are the
    same as the Canadian R1 discs.
    The Canadian DVDs seem to be a lot cheaper.
  2. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    I believe that if you buy stuff from Canada the discs are more or less the same but the Canadian discs sometimes include French 5.1 tracks - for obvious reasons - This is the case on the Toy Story 2 disc set ...
    There are however some discs made for the Canadian market and these wont be like the US stuff (or the R2 for that matter) ...
    I use www.absound.ca in Canada on a regular basis and have never come unstuck ...
    I also know that www.play247.com get alot of stuff from Canada so if its mainstream stuff you want I wouldnt worry too much ...
    "Hi my names Paul and I'm a dvdaholic ..."
  3. Arthur.S
    Arthur.S
    I believe that the Canadians apply their own 'censorship' to DVD & VHS.
    www.baldyplex.com
  4. chris
    chris
    Nov 20, 2000
    1,229
    romney marsh, kent, uk
    +29
    I've never tried one from the states, but i have a copy of stuart little on R1 NTSC that i brought second hand, and i think he got it from france,and when i play it i havet to switch to AV4 on my tv which is the NTSC channel.....but all the one's i buy from play, which are supposed to be R1 NTSC play fine on AV1 and look crap on AV4 the ntsc channel.
    STRANNNNGE...!!!!!!
