R1 phantom menace
Discussion in 'Blu-ray & DVD Players & Recorders' started by stranger, Jan 6, 2002.
  1. stranger
    stranger
    I need to crank the volume more than usual on this disc, even then speech is low,using dd5.1 track. no problems with any other disc 260 plus. any one else had similar?
  2. Ron240
    Ron240
    Jan 3, 2002
    3,617
    Kirkcaldy (but i'm not a Fifer)
    +466
    I cant speak for your particular disc as i have the R2 version and it is fine,but i have definitely noticed different volume levels on some of my DVD's.The sound on Vampires(R2) is noticeably lower. I think it's just down to the way the disc was made,in the same way as audio CD's have differing volume levels. Personally i find it a bit annoying,but unless the volume on your disc is ridiculously low i dont think there is anything wrong with it.
  3. Rachael Bitchlist
    Rachael Bitchlist
    Aug 4, 2000
    2,244
    Knocksville, Tennessee
    +71
    Stranger, it's not your imagination. PHANTOM MENACE is recorded low. Just turn it up louder and it will sound like any other DVD. One could only wish that the volume control would leave Jah Jah at the reduced level, and completely amplify only the other, fully sentient beings. Best wishes!
  4. stranger
    stranger
    thanks rachael&ron I am happy now apart from jar-jar.
