R1 DVD problem with Tosh 220e
Discussion in 'Blu-ray & DVD Players & Recorders' started by homer42, Apr 11, 2003.
  1. homer42
    homer42
    Have used multiregion Tosh 220 dvd for several months and successfully played region 1 discs. Yesterday received delivery of Panasonic PL1 TV and plugged dvd player into RGB scart. Now toshiba refuses to play region 1 dvds - error msg says not authorised. Is this just coincidence? Any ideas how to solve?
  2. BeadleMachine
    BeadleMachine
    Mar 20, 2003
    47
    Hey Homer,
    Don't know if this is relevant but I have the same TV as you. When I play R1 discs on my Pioneer DVD player via RGB I get a flickering problem.
    However, the discs do play properly. Is this error message coming up on your DVD player? If so I think it is just coincidence - I can't think why your TV would suddenly stop your DVD player from playing R1 discs :(
    Cheers,
    BeadleMachine
  3. bobbles
    bobbles
    this problem has been mentioned a few times try a search
    something to do with the chip resetting itself
    I think the solution was to burn a cd disc from net and play it in player which recodes the chip
    but as i say do a search for a detailed solution
  4. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    hi homer, make sure in the setup that pal/auto is selected as auto and then switch machine to standby and back on again.(worked for me when i had player unplugged for a week) maybe reverts to factory settings but may be talking nonsense:D
