R1 DVD Help
Discussion in 'Movie Forum' started by Tribe, Sep 25, 2004.
  1. Tribe
    Tribe
    Hello,
    I have recently been researching the possibility of a hack for my DVD player (a Panasonic DVD-RV32) to allow it to play R1 DVD's, as I am interested in buying some R1 DVD boxsets. I found a website giving a hack that is to be entered by your remote. But the problem is I have no way of knowing if it has worked or not without going ahead and ordering the boxsets, which may not play at all.
    Does anyone know a way to check if the code has worked or know of a place in the UK where you can buy a cheap R1 DVD to test with.
    Many Thanks
    Tribe
  2. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    Try cash converters or similair for cheap Reg 1.
    Dave.
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  4. Tribe
    Tribe
    Thanks for the suggestions.
    I'll give the cash converters a go and if not I'll just order something off the internet.
  5. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Have you not got a friend that can loan you an R1? :)
  6. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,473
    Somewhere in South Yorkshire
    +5,904
    I'd recommend finding a known "RCE" title if you can to fully prove it. Examples include Charlie's Angels (the 1st film); Hollow Man, Spider Man, xXx and others.
  7. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,126
    2
    In a secret location with Jennifer Lawrence
    +10,014
    Try DVDSoon.com
    You can pick up decent R1 films for only about £2 - £4 delivered.
    Greg
  8. Tribe
    Tribe
    Thanks again - I will check out DVD Soon once I get the chance.
