R1 Disc plays Black & White on my Telly
Discussion in 'Blu-ray & DVD Players & Recorders' started by rcladin, Mar 12, 2003.
  1. rcladin
    rcladin
    Hello,
    I've just recently purchased a Pioneer DV-656A and i'm very happy with it, but I have a disc that is region 1 but when I play it it shows up as black and white, all R2 discs are fine.
    Is it my Telly?, does it need to be NTSC Compatible - its an old Sanyo TV
    Any other way I can get this baby to play R1 encoded discs?
    Thanks for any help
    -r
  2. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Im pretty certain that it's you TV can't accept NTSC signals. Don't know if there is a way aound it other than a new TV :( :devil:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    To watch an NTSC disk your TV does need to be NTSC to see the disk in colour ITs the TV not the DVD player.
    I think you can get a converter but the cost would be probititive, why post in the DVD trades and see if anyone will swap R1 for R2.
    I am waiting for an RCE disk and i am not sure my player will play it but I'm going to have to give it whirl!;)
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Most likely the TV is not NTSC compatible. If it does however have a RGB capable SCART input you may use that - given the DVD has RGB out via SCART.
    Buy a fully wired SCART cable (not all are!) and activate the RGB output at the DVD player, then you should see R1 discs in color!
  5. rcladin
    rcladin
    Hi Thanks for that I changed my video output from Video to RGB on the setting menu and it worked a treat, Region 1 discs in all their colour.
    Cheers and thanks for your help man,
    Yay! can now buy cheap R1 discs online, have also seen some very cheap R3 discs online. The other good thing is that R1 movies seem to come out about 3 months before R2 discs.
    Thanks again guys
    -r
  6. zerocool242001
    zerocool242001
    just a quickie, how does one know if ur tv is rgb scart compatible, it plays region 1 disks in colour and thats from my ps2 with messiah2 chip fitted. Plus can't find the manual!!!
  7. Johndm
    Johndm
    Jan 25, 2003
    1,812
    Bedford UK
    +56
    Don't forget to check the threads on 'import duty'........:lesson:
  8. rcladin
    rcladin
    Hi Johndm,
    I see you've got some 773e speaker,
    I've currently got a single pair of them bought about 4 years ago they where £400 pounds, am looking to purchase a new home cinema setup, with a sony 1080 av receiver - a new TV, probably toshiba highly rated 32" widescreen and new speakers & subwoofer,
    just a question I could get an extra pair of mission 773e for my rear surround and a mission centre channell 771 or something like that, what do the 773e sound like in your setup ??
    Was thinking about maybe using my old 773'e as the rear and purchasing a new set of wharfdael evo 30's or monitor audio s6 or something big, any advice,
    Do you have 2 centre rear speakers?? do you need a centre rear speaker? are there 4 rear speakers in your setup?
    thanks for listening
    -r
  9. Johndm
    Johndm
    Jan 25, 2003
    1,812
    Bedford UK
    +56
    Hi rcladin,
    Your better off keeping all speakers the same for a balanced sound.
    I use 773e's for fronts and rears....sounds well cool..:smoke:
    Check out RS, they have 773e's for £169 pair!
    My centre M77c1 also came from them at £99.
    They were out of M7ds rears, so picked up some M5ds locally for £149 at Sevenoaks. Think they are a web offer this week if your quick mate.
    Use my old Technics amp to run the pair of centre rears rather than just one direct from my 555ES. Just connect a spare/old amp to the centre rear pre outs, and your away..:D
    Check the amp your after has pre outs....I guess it will have.
    Got a Gale 3080 sub (bit below par), and want to upgrade that already.
    Still, overall, well happy with the Mission setup.
    hope this helps
    regards
  10. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    From the manual you don't have. ;)
    Else just wire it up as described and activate RGB output - if you see a good looking picture you can assume the TV accepts RGB, usually on the AV1 input.
