R1 Buffy S4... 4:3 or 1.85:1?
Discussion in 'TV Show Forum' started by James45, Mar 18, 2003.
  1. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    there were rumours that this was going to be 4:3 only because the yanks don't like widescreen. has anyone seen confirmation one way or the other as CD-Wow have it down as 1.85:1.
  2. Timmy B
    Timmy B
    IGN posted the box cover and press release details which stated 4:3. They said that JW does not want season 4 to be widescreen, as it has "framing issues".
    Having seen the R2 in 16:9, the framing issues do not appear often (about 10 times throughout the season) and happen when a stock film (the moon rising or distant shot of sunnydale) is in the 4:3 format. Black bars are added, but these transition shots only last seconds.
    The only other framing issue (and probably why JW wants it in 4:3) is when Willow is far left of the 16:9 frame (out of the broadcasted 4:3 frame) and is dubbed.
    The r2 16:9 image is of a very high quality. The framing issues are rare. The 16:9 frames are not used to there potential; season 4 was very much a 4:3 show, but the extra breathing room at the sides is very welcome imho. http://www.r2-org.co.uk done a comparison between the r2 16:9 dvd and the 4:3 sky, have a search and take a look for yourself!
  3. James45
    James45
    Sep 21, 2002
    2,844
    59
    link doesn't seem to work, are there comparison screenshots?
    you mentioned stock film in 4:3, are the bars on the disc or does it prompt a switch to 4:3 on the display?
  4. Timmy B
    Timmy B
    Sorry about the link, I meant http://www.r2-dvd.org. Use the search engine in there. Yes there are screenshots.
    The transitions are 16:9 but have black bars. It does not happen on every one, just where they didn't have a 16:9 copy of it. About 10 times or so, they are so quick you hardly notice.
    You can get this boxset for £40 r2 from dvd.co.uk btw.
  5. James45
    James45
    Sep 21, 2002
    2,844
    59
    couldn't find the screenshots but I'll be getting the R2 for £40 in that case. Thanks.
    Now where do I find Angel Season 1 in widescreen?
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Season four R2 is £60 everywhere!:(
  7. Timmy B
    Timmy B
    Oops, sorry, thought it was 40 at dvd.co.uk, but alas only seasons 1-3:(
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    any idea if angel season 1 is available anywhere in widescreen, if not I'm off to order R2's of season 1 and 2 instead of Buffy.
  9. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    Angel series 1 is 4:3 everywhere (AFAIK)
  10. James69
    James69
    I prefer Buffy and Angel in 4:3 anyway - it feels much more claustrophobic :smashin:
    If it was a film then that's different, but its only a tv show.
  11. James45
    James45
    Sep 21, 2002
    2,844
    59
    is that name fan worship or are you taking the ****?
  12. Hobgoblin
    Hobgoblin
    If thats the case, how come all region one discs aren't in 4:3 :rolleyes:
  13. darthvader
    darthvader
    Season one of Angel is only available in 4:3 because the w/s version was lost in a fire, so I've heard.
  14. James45
    James45
    Sep 21, 2002
    2,844
    59
    there are petitions in the US to do just that. widescreen displays are not the norm over there as they are becoming over here, the yanks don't like their black bars. and stop spoiling for a fight!:boring:
    Apocalypse answer your PM mate, where did you get your R1 Angel from?
  15. Timmy B
    Timmy B
    BTW James, dvdfile reported a problem on the earlier episodes of the r1 season 1 of angel. Strange picture artifacts:
    If you want to buy it r2, try this link:
    http://www.dvd.co.uk/product.asp?id=22830DVD
  16. James45
    James45
    Sep 21, 2002
    2,844
    59
    cheers!:smashin: unless Apoc gets back to me soon and tells me the picture prob isn't that noticable (because he said before that the R1 sound is amazing) I'll be ordering R2 of both today! Woo Hoo... weekend marathon!!:clap:
  17. Timmy B
    Timmy B
    If it helps, I have the r2 and a HGS-15 and must agree with apoc, the bass in angel makes you wonder if, unlike most TV shows (accept Roswell), the sound designers know what they are doing.
    have you seen these before, or is this a virgin screening?
  18. James45
    James45
    Sep 21, 2002
    2,844
    59
    upgrading from my treasured VHS collection which I really should get rid of once replaced (although I doubt I'll be able to bring myself to do it:D ). Are you watching the current series on Sky? without wanting to sound all fanboy... OMG:eek: !!
  19. Timmy B
    Timmy B
    Yeah, the last two eps have been so good! Apoc nowish was so cool at the end, wesley with the dual handguns:) Its a shame that alot of the fight scenes are hard to following due to previously discussed cropping, but hey thats another reason to buy the DVDs:)
    Enjoy!
    BTW, if roswell high ever comes to DVD, you must buy it. Not only does it kick angel and buffy ass(and I am a huge bufy and angel fan), it has the best sound design I have every heard from a TV show. Massive bass, almost constant surround use (and lots of split surround effects when using PL2).
  20. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    On a slightly unrelated topic (and it might have already been said on here), Once More With Feeling is getting released the same day as series 6. The OMWT disc will have a 5.1 sound track :clap: ...but the series will only have 2.0.
    Looks like I'm buying both then :rolleyes:
  21. Timmy B
    Timmy B
    Actually, I have heard from every1 who has the pre-release review version that once more is 2.0. The 5.1 is a mistake on the press release.
  22. James45
    James45
    Sep 21, 2002
    2,844
    59
    ordered angel seasons 1 and 2 from dvd.co.uk for £80 last night at around 10.30. I've just checked and both were posted at 9.30 this morning!:eek: Great service!:smashin:
  23. Timmy B
    Timmy B
    Aye, I have never had a problem with them.:smashin:
