R1 2:35 16:9 Enhanced
Discussion in 'Movie Forum' started by Stellavision, Jun 17, 2003.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    found on my newly aquired R1 dvd's, Blade and Pearl Harbour, that they are 2:35 Aspect Ratio but are enhanced for 16:9 tv's.
    This I find very good as I get less black at the top and bottom of the screen.
    Do all R1 2:35 dvd's have this 16:9 enhancement?
    I'll be rushing to swap my R2 2:35 faves like the Matrix if this is the case.
  2. sweetmate
    sweetmate
    Aug 29, 2001
    706
    London
    +51
    Not all R1 2.35 films are enhanced for 16:9 TVs and not all R2 2.35 are not. It depends on the disc.
    And you shouldnt have any less or more black at the top and bottom of the screen if you are viewing an anamorphic or non-anamorphic 2.35 film on a 16:9 TV. If this is the case then you are viewing one or the other in the wrong widescreen mode.
    P.S. R2 Matrix is enhanced for 16:9.
  3. nathan_silly
    nathan_silly
    So why is it The Thing (2:35 Non Anamorphic) has whopping great borders? Wheras a 2:35 Anamophic (LOTR) has smaller borders?
    Watching in Wide mode.
  4. sweetmate
    sweetmate
    Aug 29, 2001
    706
    London
    +51
    Because you shouldnt watch a non anamorphic image in Wide mode, it should be in zoom mode (this is the name for it on Sony and Panasonic TVs, it might be different on others).
    I shudder to think how many non anamorphic DVDs youve watched in wide mode!!
  5. nathan_silly
    nathan_silly
    But when I zoom in (Cinema) on the R1 The Thing I can see the scan lines.
    I haven't watched a Non Anamorphic DVD since getting my new TV, so haven't set the aspect mode for Ana/Non Ana films.
  6. sweetmate
    sweetmate
    Aug 29, 2001
    706
    London
    +51
    Hence the term "Enhanced for 16:9 TVs".
    I'd rather see the scanlines than watch a film that has been distorted so everyone has fat heeds!
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    I've always left my Hitachi plasma on auto while watching DVD's thinking it would find the correct aspect ratio. I've just found that it does'nt work like that.
    Where R1 Blade gave me a 2.5 cm black line at the top while on auto, R2 Matrix gave me a 5 cm black line. I fiddled with the screen setting and on changing to 14:9 zoom I got the same picture size (2.5 cm black line at the top) as Blade did set in auto.
  8. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Wide, 4:3 and Zoom (Non-A only) modes are the only modes you should ever use and will ever need.
    Using anything else will only result in some loss of picture or distortion.
    Perhaps the difference in size of borders is caused by the difference in the number of scan lines/resolution between ntxt and PAL.
  9. Squirrel God
    Squirrel God
    The size of the black borders may differ between non-anamorphic and anamorphic 2.35:1 because of different overscan settings in those modes on the display.
    Non-anamorphic 2.35:1 NTSC is unbearable for me. There are some DVDs that are only available on Reg 1 or only available on Reg 1 in the OAR, but they are non-anamorphic 2.35:1 so I have just downright refused to buy them.
  10. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Me too, I would not buy a non-anamorphic 2.35:1 NTSC DVD; you don't exactly get many pixel lines of picture, at least PAL would give you 20% more lines. Even then, I just don't buy non-anamorphic DVDs -- 4:3 ones accepted. ;)
    StooMonster
  11. Squirrel God
    Squirrel God
    I have been known to buy non-anamorphic PAL if that's all that's available, and non-anamorphic 1.85:1 NTSC if it's dirt cheap and also all that's out there. Don't own many though!
    As an aside, The Abyss SE is 2.35:1 non-anamorphic PAL and it's amazing how good the PQ is considering :)
  12. Garrett
    Garrett
    Apr 21, 2001
    40,233
    2
    167
    The best thief you’ll never see.
    +6,659
    The only non anamorphic thing I have on disc are those that where originally broadcast in 4:3.
    I was surprised that such a recent film as The Abyss was non-anamorphic.
  13. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    :eek: That is what I meant.
    Would not even consider buying a "pan and scan" version of a movie, and if given one for free would sell it on to a muppet that would. ;)
    StooMonster
  14. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Won't it effectively be a higher bit rate? All those extra black lines mean less active lines to encode, so more detail can be stored about those active lines -- that's the theory anyway.
    StooMonster
  15. WBC
    WBC
    Sweetmate,
    Based on your theories of watching non-anomorphic in Zoom mode (Which I don't do!!!) What settings on a Sony would you suggest for each format, ie 1.85, 2.35:1 etc???
    I tend to leave my TV in wide mode, now I'm guessing its completely wrong. What should I have it to????
    Stacy
  16. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    There are always right and wrong ways to do things. However, at the end of the day, it is you who are watching, and you have a choice as to what suits you best.
    It is 'wrong' to watch a widescreen, non-anamorphic DVD, on a widescreen display, on anything else than the 'zoom' mode* (or whatever your TV manufacturer calls it) because things will be the wrong shape.
    But - zooming does spread the scan lines. If you prefer closer scan lines and distorted images - then you are free to make that choice.
    * (or 4x3 mode - but then you'd have black edges on all 4 sides of the image and a small active picture - you may prefer to do that of course).
    Here is the proper way to do things (if you like), assuming a 16x9 TV (etc) and your DVD player is set correctly:
    Any anamorphic/enhanced for WSTVs signal: 'Wide' mode (*1)
    Any non-anamorphic signal where the active part of the image is 16x9 or wider: 'Zoom' mode (*2)
    Any non-anamorphic material where the active part of the image is taller than 16x9: '4x3' or 'normal' mode (*3)
    (*1) 'Wide' mode is where the video signal (which may include some plain black parts) just fills the screen in both directions (+/- a bit of overscanning)
    (*2) 'Zoom' mode is where the video signal (including any plain black parts) just fills the screen horizontally, and significantly exceeds the screen height vertically. Not all of the video signal is shown, but the part that is missing is plain black so you don't lose anything important
    (*3) '4x3'/'normal' is where the video signal just fills the screen vertically and is significantly narrower than the screen horizontally.
  17. Garrett
    Garrett
    Apr 21, 2001
    40,233
    2
    167
    +6,659
    I wasn’t referring to you but Squirrels post. ;)
    I have seen some that pictures that need zooming as extras on DVD and thy look far worse than stuff that has to be zoomed on TV. I cannot see why The Abyss was realised in such a way, it seems very sloppy.
  18. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    I wouldn't dream of watching a film in anything other than the correct AR, TV and TV based DVDs are another matter though and I will watch them in smart mode.
    If you don't like the scan lines then don't buy NTSC non-anamorphic 2.35:1 discs... but whatever you do please don't stretch it in wide!!
  19. CarlB
    CarlB
    Jan 8, 2001
    1,291
    Cambridgeshire
    +221
    The R1 disc of The Abyss was released in non-anamorphic widescreen as, at the time of release, Cameron perceived the number of US 4:3 displays vastly outnumbered the number of 16:9 displays. Anamorphic discs at the time came in for a large amount of criticism on the US forum boards, due to poor downscaling of the anamorphic image by the DVD player. This meant that the majority of the US viewing public were subject to inferior quality video with anamorphic discs when they were viewed on their 4:3 sets.
    Thankfully, the drive to HDTV in the US has led to greater acceptance of 16:9 displays so the situation is now reversed at long last. Also, the modern DVD player is much better at downscaling the anamorphic image for a 4:3 display so the complaints from 4:3 owners seem to have fallen away.
  20. Garrett
    Garrett
    Apr 21, 2001
    40,233
    2
    167
    +6,659
    But wasn’t it only released about a year ago? When the vast majority if not all the other where being released in anemographic.
  21. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    I'm not convinced about all this, now, and remain a little confused.
    My Attack of the clones (R2) is 2:35:1 Anamaphoric widescreen but displays a 5cm black line at the top and bottom when watched in auto or wide mode.
    When I switch to 14:9 zoom a get only 2 cm black lines the same as my R1 'Enhanced for 16:9 TV's' disks when my tv is on auto or wide mode.
    So what is the correct way to view these R2 2:35's? In wide or 14:9 zoom?
  22. sweetmate
    sweetmate
    Aug 29, 2001
    706
    London
    +51
    Watch anamorphic DVDs in Wide and Wide only.
  23. Squirrel God
    Squirrel God
    Not a higher bitrate but given fewer 'active' lines more 'bang for buck' with the same bitrate, if they decided to take advantage of that :)
    Be careful comparing non-anamorphic extras with non-anamorphic feature films. Non-anamorphic features usually look a lot better as extras like deleted scenes tend to come from dire sources anyway :)
    You are getting aspect ratios and 16x9 enhancement (aka anamorphic widescreen) confused.
    You get black bars on both anamorphic 2.35:1 and non-anamorphic 2.35:1.
  24. Garrett
    Garrett
    Apr 21, 2001
    40,233
    2
    167
    +6,659
    I was wondering about that and was wondering if somebody knew something I didn’t.:rolleyes:
  25. CarlB
    CarlB
    Jan 8, 2001
    1,291
    Cambridgeshire
    +221
    No, The Abyss R1 was released as a 2 disc SE in 2000, last year's release was just a re-release as a single disc.
  26. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    And if you're still confused (and I wouldn't blame you if you were), use the video tests on a disk with THX Optimode to test that you've got you're screen set correctly.
    There are both normal & anamorphic tests on there.
  27. LV426
    LV426
    Jul 14, 2000
    13,424
    +5,823
    Assuming that the TV and DVD are setup correctly, and you choose the correct screen mode, there should be no difference in the shape of the active part of the image on, say, a 2.35:1 movie, between:
    a) an anamorphic NTSC disc
    b) an anamorphic PAL disc
    c) a non-anamorphic NTSC disc
    d) a non-anamorphic PAL disc.
    Any differences that do arise are either due to operator error, different ratios of the films themselves (or their transfers to DVD) or maladjustment in the TV. (or your imagination!)
  28. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Still the case today.
    Unless this has changed in the last few months, I disagree that there is greater acceptance of 16:9 displays. When I was last in AV stores in the USA (through-out last year in East Coast, West Coast and other countries in the Americas) they were full of 4:3 sets -- but giant ones! There was the odd 16:9 plasma and RPTV, but they even had 4:3 plasmas.
    I've got friends in US who've recently bought 4:3 tvs as their perception is it's normal tv and widescreen is for AV nuts, whereas everyone I know here's had 16:9 ones for years.
    IMHO the general US public remains highly resistant to changing to 16:9 ratio screens, AV enthusiasts aside.
    StooMonster
  29. Squirrel God
    Squirrel God
    Hence the much more frequent release there than here of dual widescreen and P&S/full-screen DVDs (either in the same package or available separately) :(
  30. CarlB
    CarlB
    Jan 8, 2001
    1,291
    Cambridgeshire
    +221
    4:3 displays still outnumber installed screens in the US, but as HDTV is a native 16:9 display there are definite gains in the acceptance of 16:9 in the US now. Without HDTV I still think we might be seeing non-anamorphic DVDs, it's only the understanding that everything is 'going' HDTV/16:9 that is providing some impetus. Two of my friends in the US have recently bought 16:9 HD displays to watch the HiDef US football next season, and it seems that HiDef sports in one of the main driving factors pushing HDTV.
    I know what you mean about most stores in the US though. When I was in Fry's and Best Buy you couldn't move for hulking 100" 4:3 RPTVs and the like, but bear in mind these stores are the (much larger) equivalent of our Dixons et al, pushing mainstream fare for the masses.
