-r/-rw
Discussion in 'Blu-ray & DVD Players & Recorders' started by rulett, Apr 6, 2003.
  1. rulett
    rulett
    does anyone know if the panasonic dmr-e50 will record to dvd-rw and if so will these play in the toshiba 220e.what i'm thinking is if i record to dvd ram i wont be able to play them in the tosh in the bed room ,but if i finalise to dvd-r i'll have to keep the recording,which is rather expensive for every day recording.:confused:
  2. bobbles
    bobbles
    E50 Will only record to -RAM and -R not -RW
    day to day recordings need to be done on -RAM you will not be able to play these on your 220
    archiving needs to be done on -R, after finalising this will be compatable with your 220
    Your only option is to buy a different second dvd player, Toshiba do some reasonably cheap -RAM players
    S35
  3. rulett
    rulett
    As i feared,cheers mate.
